How to compare strings/array? RFID Project
Results 1 to 40 of 101
    I see. OK, thanks.
    What is you opinion about the display? (colors, brightness, sharpness).
    Nov 2006
    Murrieta, CA
    Default uOLED-128-G1 Opinion
    Overall the display is great. you have full control over any text you send to the display: positioning (x,y), Color(msb:lsb), and even font size. you can even make custom bit mapped color characters and store them on a uSD card. Or even tell the uSD to run a script.
    cmd,column,row,font,Color(msb:lsb),“string”,Termin ator ($00)
    My next goal is to have the PIC play a video from the uSD card. the only obsticle i see is you have to know a lot of information about memory structure, like sectors and such, to address the uSD card. here is the video command info:
    Command ext_cmd, cmd, x,y,width, height, colourMode, delay, frames(msb:lsb), SectorAdd(hi:mid:lo)
    - ext_cmd 40(hex) or @(ascii) : Extended Command header byte
    - cmd 56(hex) or V(ascii) : Command header byte
    - x : Video horizontal start position (top left corner).
    - y : Video vertical start position (top left corner).
    - Width: Horizontal size of the video-animation.
    - Height: Vertical size of the video-animation.
    - ColourMode 08(hex) : 256 colour mode, 8bits/1byte per pixel. 10(hex) : 65K colour mode, 16b/2B per pixel .
    - Delay : 1 byte inter-frame delay in milliseconds.
    - Frames: 2 bytes (big endian) total frame count in the video-animation clip.
    - SectorAdd : 3 bytes (big endian) sector address of a previously stored videoclip that is about to be displayed.
    From the pdf that are available, I could not find the specs for the video files.
    What files the LCD can play?
    Nov 2006
    Murrieta, CA
    Thumbs up I got it
    Hey Ioannis,
    I got video to play on the display from the PIC..
    once i get the project up and complete ill write a tutorial on the process.
    Okie, looking forward...
    Nov 2006
    Murrieta, CA
    Default Re: I got it
    Ioannis,
    The video Tutorial On the 4Dsystems OLED is located in the Code Example section. link below.
    Displaying Videos and Images on 4Dsystems uOLED Serially
  1. Parallax RFID Reader code example
    By dan-tron in forum Code Examples
    Last Post: - 19th April 2013, 23:16
  2. A Temperature & Humidity Data Recorder Project
    Last Post: - 9th July 2008, 19:47
  3. Replies: 3
    Last Post: - 12th March 2008, 06:33
  4. Free Web based RFID Online Courses
    By Thirumoorthy in forum General
    Last Post: - 19th November 2007, 14:38
  5. Free web based RFID online Course
    By Lesikar in forum GPS
    Last Post: - 19th October 2007, 23:28
