EUREKA!
Thanks guys! You have been a huge help. I have finally figured it out.
My problem was more like 3 problems...
1. I have never done EEPROM stuff before so I was lost to begin with.
2. As Bruce pointed out, the mathematical order of operations in one line was not correct. I guess the BS2 thinks a little differently from PBP in that respect.
3. My PicBasic Pro compiler was Version 2.30 form 2000. It seems that v2.30 supports the PIC 16F628 but the PIC 16F628A was implemented in a later version. I have upgraded my PBP to version 2.47 and now the EEPROM features work correctly on the 16F628A. When I successfully tested a 16F84A using the same code, that lead me to question the compiler.
So for future generations and the benefit of other people like me, here's my WORKING code that is tested successfully on a PIC 16F628A with a 20MHz resonator compiled using PBP v2.47. It reads data from the Parallax RFID Reader Module, compares it against known values stored in EEPROM and allows or denies access accordingly. Enjoy.
Code:CMCON = 7 DEFINE OSC 20 'Set oscillator in MHz ' -----[ Variables ]------------------------------------------------------- buf VAR Byte(10) ' RFID bytes buffer tagNum VAR Byte ' from EEPROM table idx VAR Byte ' tag byte index char VAR Byte ' character from table ' -----[ EEPROM Data ]----------------------------------------------------- Tag1 DATA "100050A4B7" Tag2 DATA "1000508E0A" Tag3 DATA "10005091DC" Tag4 DATA "100050203A" Tag5 DATA "100050DA36" ' -----[ Initialization ]-------------------------------------------------- HIGH portb.3 ' turn off RFID reader LOW portb.6 ' lock the door! Low portb.4 'Turn off LED ' -----[ Program Code ]---------------------------------------------------- Main: LOW portb.3 ' activate the reader SERIN2 portb.2, 396, [WAIT($0A), STR buf\10] ' wait for hdr + ID HIGH portb.3 ' deactivate reader Check_List: FOR tagNum = 1 to 5 ' scan through known tags FOR idx = 0 TO 9 ' scan bytes in tag READ (((tagNum-1) * 10) + idx), char ' get tag data from table IF (char <> buf(idx)) THEN Bad_Char ' compare tag to table NEXT GOTO Tag_Found ' all bytes match! Bad_Char: ' try next tag NEXT Bad_Tag: tagNum = 0 FREQOUT portb.5, 1000 */ $100, 115 */ $100 ' groan PAUSE 1000 GOTO Main Tag_Found: HIGH portb.6 ' remove latch High portb.4 ' Light LED FREQOUT portb.5, 2000 */ $100, 880 */$100 ' beep LOW portb.6 ' restore latch Low portb.4 ' LED OFF GOTO Main
