You might try using WRITE to store the data. That might isolate the problem to your DATA or READ statements.
Maybe this one will help you.
I donīt try before working with SERIN2 but give it a try. You can change this part with storing data to eeprom too. Itīs only to see how to realize that, if iīm not wrong.
To store data on eeprom use
DATA @$00,$D7,$7C,$4B,$02,$2D,$C9,$80,$3A,$C4,$72
Code:Loop VAR BYTE ReadTag VAR BYTE[2] ConvTag VAR WORD Tag VAR WORD[5] Tag(1) = $D77C Tag(2) = $4B02 Tag(3) = $2DC9 Tag(4) = $803A Tag(5) = $C472 ' -----[ Program Code ]---------------------------------------------------- Main: LOW PORTB.3 ' activate the reader SERIN2 PORTB.2, T2400, [WAIT($0A,"100050"), STR ReadTag\2] HIGH PORTB.3 ' deactivate reader Check_List: ConvTag = ReadTag(0)*$100 + ReadTag(1) FOR Loop = 1 to 5 IF ConvTag = Tag(Loop) THEN Tag_found NEXT Loop GOTO Bad_Char Bad_Char: ' try next tag '.... '.... GOTO main Tag_Found:
Are you sure you're programming your tag numbers in EEPROM at burn time? You should be
able to read back the .hex after programming to check.
I donīt wrote the code before for storing on eeprom.
But maybe this could work
Error corrected... SorryCode:DATA @$00, $D7, $7C, $4B, $02, $2D, $C9, $80, $3A, $C4, $72 Loop VAR BYTE ReadTag VAR BYTE[2] Tag VAR WORD[5] TmpTag VAR BYTE[10] ConvTag VAR WORD ' -----[ Program Code ]---------------------------------------------------- FOR Loop= 0 TO 9 ' Reading Data from EEprom Adr: $00 -$09 READ Loop,TmpTag(Loop) NEXT Loop Main: LOW PORTB.3 ' activate the reader SERIN2 PORTB.2, T2400, [WAIT($0A,"100050"), STR ReadTag\2] HIGH PORTB.3 ' deactivate reader Check_List: FOR Loop = 0 TO 8 STEP 2 ' Calculate Word from HighByte + LowByte Tag(Loop/2) = TmpTag(Loop)*$100+TmpTag(Loop+1) NEXT Loop ConvTag = ReadTag(0)*$100+ReadTag(1) ' Conversion of ReadTag to WORD FOR Loop = 0 TO 4 ' Compare if ReadTag compares to Database in Eeprom IF ConvTag = Tag(Loop) THEN Tag_found NEXT Loop GOTO Bad_Char Bad_Char: ' try next tag '.... '.... GOTO main Tag_Found:
I have simplified my program to isolate the issue. I believe it lies with the READ command. This is my simplified code.
At this point I am just trying to read a byte form the EEPROM and display it on the LCD just to prove it is being read. I see the EEPROM data in the EEPROM data window on my EPICWin programming software. So I guess it is writing the EEPROM data at burn time. However all I can debug on the LCD so far is just 0. This leads me to think that the problem is with the READ command. With the above example I would think that the LCD would display 2A or at least something other than just 0's.Code:CMCON = 7 DEFINE OSC 20 char VAR Byte ' character from table ' - LCD Stuff - i con 254 clrlcd con 1 cgram con 64 ddram con 128 n96n con $4054 pause 1000 serout2 portb.7,n96n,[i,clrlcd] pause 1 Tag1 DATA @$00,$10,$2A,$54,$FF,$7C Main: READ $02, char ' get tag data from table 'Debug to LCD serout2 portb.7,n96n,[i,clrlcd] pause 500 serout2 portb.7,n96n,[i,ddram+0] serout2 portb.7,n96n,[HEX char] serout2 portb.7,n96n,[i,ddram+6] serout2 portb.7,n96n,[DEC char] pause 1000 end
"Program/Verify Data" must be checked for it to write EEPROM data when programming.
<img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1940&stc=1&d=118807518 2">
I already have the "Program/Verify Data" option checked. Also if I Read the chip after Programming it, I do see the EEPROM data present in the Data EEPROM window. So it's definitely writing to the EEPROM. It's just not reading it for some reason.
Also some other things I tried just now was switching to the internal 4MHz resonator and trying a second chip in case it was a bad chip. Neither made any difference.
