How to compare strings/array? RFID Project
Results 1 to 40 of 101
    Oct 2010
    Default Re: How to compare strings/array? RFID Project
    Dear all,
    the project for my home up to now works OK!.
    Here is also a 3D printed case i have designed in order to place nice and clean all the components and electronics.
    Oct 2010
    Dear all,
    i have a small problem with my code and circuit.
    After 3 or 4 tries, maybe less maybe after 2 or 3 minutes.....(it is strange) when i pass the RFID from the reader, the first circuit, works perfect, but the second circuit, looks like does not listen to any command from the keypad.
    It looks like that it gets power from the first circuit, but when i try to press any button from the Keypad, does not respond.
    here is the code of the circuit that is related to the keypad.
    If you notice, i havent add any commands for the fuses....because when i did that i was getting errors
    ;@ DEVICE pic16F84A, HS_OSC, WDT_OFF, PWRT_ON, PROTECT_OFF --> this is not working.
    ;@ __config _HS_OSC & _WDT_OFF & _PWRTE_ON & _CP_OFF --> this was passing the first error the counldnt find the PIC16F84A but i was getting an error (2007)
    The problem is: If i load the code without fuses, the program and circuit works fine on the test board.
    When i transfer it to the PCB after 2-3 minutes when i try to pass the TAG from the reader, the Keypad looks like that is not responding.
    '*  Name    : CodeLock.bas                                      *
    '*  Author  : xxxxxx                                            *
    '*  Date    : xxxxxxxxxx                                        *
    '*  Notes   : Programable Code Lock with the PIC-16F84          *
    ; Change the code from 1234 by typing the code 1234 then * 1961#1961#
    Include "MODEDEFS.BAS"
    RL1_ON_time con 1000 * 5  'sec. Relay ON time
    TrisA = 0  ' PORTA, all outputs
    PortA = 16 ' turn off Buzer
    OPTION_REG.7 = 0   ' PORTB Pullups.
    TrisB = %11110000  ' PORTB.0-3 outputs, 4-7 inputs
    PortB = 0
    LD1 var PortA.2
    RL1 var PortA.3
    BUZ var portA.4
    cnt var byte
    key  var byte
    col  var byte
    row  var byte
    keycnt var byte
    pwOK var bit
    keybuf var byte[15]
    pwbuf var byte[4]
    EEPROM 0,[1,2,3,4] 'Default password 1,2,3,4 programmed at EEprom location 0..3
    Read 0, pwbuf[0]   'Copy password from EEprom address 0..3 in to pwbuf[0..3]
    Read 1, pwbuf[1]
    Read 2, pwbuf[2]
    Read 3, pwbuf[3]
    pwOK = 0
    keycnt = 0
        high ld1
        pause 1
        gosub Chk_KEYPAD
    goto Main
    Chk_KEYPAD:
       for row = 0 to 3
          PORTB = (dcd row) ^ $f
          pause 1
          col = PORTB >> 4
          if (col <> $f) then  'key pressed
             key = (row * 3) + (ncd (col ^ $f))
             gosub Got_KEY
             key = 255
       next
    Beep:
       low ld1
       low buz
       pause 40
       high buz
    Got_KEY:
       gosub Beep
       while (PORTB >> 4) <> $f
          pause 1
       wend
       if key = 11 then key = 0
       keybuf[keycnt] = key
       gosub Chk_keycnt
    Chk_PwOK:
       PwOK = 0
       if (keybuf[0] = pwbuf[0]) and (keybuf[1] = pwbuf[1]) and (keybuf[2] = pwbuf[2]) and (keybuf[3] = pwbuf[3]) then pwok = 1
    Chk_NewPwOK:
       PwOK = 0
       if (keybuf[5] = keybuf[10]) and (keybuf[6] = keybuf[11]) and (keybuf[7] = keybuf[12]) and (keybuf[8] = keybuf[13]) then pwok = 1
    Pw_Change:
       pwbuf[0] =  keybuf[5]
       pwbuf[1] =  keybuf[6]
       pwbuf[2] =  keybuf[7]
       pwbuf[3] =  keybuf[8]
       Write 0, pwbuf[0] 'Store new password to EEprom location 0..3
       Write 1, pwbuf[1]
       Write 2, pwbuf[2]
       Write 3, pwbuf[3]
    Chk_keycnt:
       select case keycnt
          case 4
             gosub Chk_PwOK
             if pwOK then
                if keybuf[keycnt] = 12 then Access_OK
                if keybuf[keycnt] <> 10 then Clr_keybuf
                gosub Beep
                goto Clr_keybuf
          case 9
             if keybuf[keycnt] <> 12 then Clr_keybuf
             gosub Beep
          case 14
             gosub Beep
             gosub Chk_NewPwOK
             if pwOK then
                gosub Beep
                gosub Pw_Change
                gosub Beep
                goto Clr_keybuf
                goto Clr_keybuf
          case else
             if keybuf[keycnt] = 12 then Clr_keybuf
       end select
       keycnt = keycnt + 1
    Access_OK:
       High RL1
       pause RL1_ON_time
       low RL1
    Clr_keybuf:
       for cnt = 0 to 14
          keybuf[cnt] = cnt
       next
       keycnt = 0
    goto Main
    Quick reply to this message Reply    Reply With Quote Reply With Quote    Multi-Quote This Message
    Oct 2010
    Ok,
    first thing first. I will edit the ,inc file and commend it in order to avoid the error 2007
    overwritting previous address contents (2007)
    then i will see if that works. I will post results tomorrow afternoon.
    Which compiler you use now?
    Oct 2010
    an old one, as far as i remember is the 2.6b
    Then yes, you should edit the *.inc file first the way you stated.
    Oct 2010
    Thanks Ioanni.
    In case of the newer version, should i have to edit again the .inc files?
    Let me first fix the code and then will discuss further.
  1. Parallax RFID Reader code example
    By dan-tron in forum Code Examples
    Last Post: - 19th April 2013, 23:16
  2. A Temperature & Humidity Data Recorder Project
    Last Post: - 9th July 2008, 19:47
  3. Replies: 3
    Last Post: - 12th March 2008, 06:33
  4. Free Web based RFID Online Courses
    By Thirumoorthy in forum General
    Last Post: - 19th November 2007, 14:38
  5. Free web based RFID online Course
    By Lesikar in forum GPS
    Last Post: - 19th October 2007, 23:28
