Using PICBASIC PRO in MPLAB IDE
Results 1 to 9 of 9
Threaded View
  1. #5
    Quote Originally Posted by boroko View Post
    HI all,
    My problem is different than the original thread, but the title fits, so I'll post it here.
    I have been using MCS and PBP for a while, and never managed to really "use" MPLAB. It seem that every time I try, I fall into a "pit of death" and get frustrated and ignore it again.
    Well, I have a troublesome program, and I need to see it in a simulator. After looking around, it seems that MPLAB has it if I can figure out the hurtles. I was encouraged to try again by Chuck Hellebuyck's article in N&V and it seemed so easy. HA! again the gremlins have their way with me!
    I have MPLAB 7.60 in C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe (default) PBP is 2.47. In MPASM points to C:\PBP\PBPW.exe (default) copied the .inc files as mentioned.
    Ran PBPlugins.bat and checked the path on my computer.
    It is:
    C:\MCC;%SystemRoot%\system32;%SystemRoot%;%SystemR oot%\System32\Wbem;C:\Program Files\Common Files\Roxio Shared\DLLShared;C:\Program Files\QuickTime\QTSystem\;C:Program Files\Microchip\MPASM Suite;C:\PBP
    >Executing: "C:\PBP\PBPW.EXE" -ampasmwin -oq -z -p16F690 "BLINK.BAS"
    >PICBASIC PRO(TM) Compiler 2.47, (c) 1998, 2006 microEngineering Labs, Inc. All Rights Reserved.
    >ERROR: Unable to execute mpasmwin. Halting build on first failure as requested.
    >BUILD FAILED: Sat May 03 06:58:40 2008
    I reassigned the paths and got the same error.
    I would love to learn to use MPASM, but it seems that I keep running into problems like this and get frustrated.
    Can anyone see something that I’m missing?
    Thanks again
    Mark
    P.S. The whole reason for this round of gymnastics is to try and figure out a motion control glue board that I need.
    If anyone cares to look it over and offer any ideas, they would be greatly appreciated.
    I’m hoping that by seeing it in a simulator, I can get some ideas on where the problem is.
    I have been working in MicroCode Studio and using Darrel Taylor’s DT_INTS-14-0.bas for handling the interrupts.(the “-0” is a mod for 0 banks on the 12F).
    The code that I have follows:
    <code>
    '* Name : encTest12F675-6.BAS *
    '* Author : Mark A.Rokus *
    '* Notice : Copyright (c) 2008 Controlled Surroundings Inc. *
    '* : All Rights Reserved *
    '* Date : 4/12/2008 *
    '* Version : 6.0 *
    '* Notes : 12F675@4mhz, INT_OSC *
    '* : PBP 2.47, MPASM: 5.11, 282 words used *
    '* : Need to test *
    '* : LAST: Trav works if not too fast, Manual erratic *
    '* : and locks auto travel sometimes *
    ' 1)Quadrature encoder reading direction and speed of mechanical slide.
    ' 2) Motor (servo) driven in ONE direction of slide movement,
    ' not driven for other direction. Active LOW Pulse & Direction drive.
    ' 3) another Manual Encoder to drive servo either direction manually.
    ' ADD pull-up to GPIO.3 on 12F675
    '_CONFIG INT_OSC?
    'move to different chip
    <FONT COLOR=RED>'How do you set the DEVICE for MCS & MPASM?</FONT COLOR>
    ' Test "end of Travel- up" for manual feed
    </code>
    ________________________________________
    Hi Mark,
    Try these ,
        ifndef __12F675
            error "12F675 not selected"
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
        PCON = %00000011    ' BOD off, No POR flag set
    DEFINE  NO_CLRWDT 1
        OSCCAL = %1111100   ' SET OSC TO MAXIMUM SET OSC TO 4 MHZ INTERNAL
  1. Conversion from picbasic pro to hex for mplab
    By pr2don in forum Forum Requests
    Last Post: - 10th October 2010, 19:53
  2. picbasic pro and mplab IDE
    By soelinnhtet in forum mel PIC BASIC Pro
    Last Post: - 1st March 2010, 08:57
  3. 16F636 Picbasic pro 2.60 / MPLAB 8.43 / Windows 7
    By mathubbard in forum mel PIC BASIC Pro
    Last Post: - 19th February 2010, 15:50
  4. PICBASIC Pro & MPLAB integration syllabus
    By chris vp in forum PBP Wish List
    Last Post: - 25th July 2009, 10:35
  5. Upgraded to MPLAB IDE 8.14 and now I'm stuck
    By BlueHairBob in forum General
    Last Post: - 20th August 2008, 01:15
