Adding picKIT to MICROCODE STUDIO
Results 1 to 6 of 6
    May 2008
    Default Adding picKIT to MICROCODE STUDIO
    I am just starting with PICs. I have a PICKIT1 programmer and it works fine, I can program to it with the pickit1 classic program, but I am having trouble adding it to my list of programmers from the MIRCOCODE STUDIO.
    So far everything I've tried has not worked - is there another program that PICKIT uses?
    The PICKIT Classic is the only one I know of.
    I have not used it for some time, but worked well.
    Is the PIC Classic not updating the hex or not executing?
    I will try it here tonight and see if there are problems with MCS3.0.
    Yikes, sorry i don't know for PICKIT1.. but PICKIT2 have command line and it's pretty easy to add it to MCS.
    Maybe you could try with Piklab?
    http://piklab.sourceforge.net/
    HTH
    Feb 2003
    Sydney, Australia
    I just got my PicKit2 and it is the best $40 I have spend for quite some time.
    You will need to download the command line tool from the Microchip site - do a search for PKCMD2.exe. You can then call it from MCS using the following command line:
    /PPIC$target-device$ /F$hex-filename$ /M -h3
    I currently use my other USB programmer in ICSP mode (DIY Kiys K150) to program and use the PicKit 2 as a logic analyser. Its fantastic !
    Oops, just noticed you have the PicKit 1 - sorry not sure....
    Bill.
    Last edited by bcd; - 4th May 2008 at 03:34. Reason: Realised original poster has PicKit 1....
    May 2008
    Thanks I tried the PK2CMD and the command line paramters you posted, but it didn't work for me.
    I searched the MICROCHIP website and there was nothing else for PicKit1, It is not too
    big of a deal, it is just a couple of extra steps to use the CLASSIC
    I did not have much luck.
    No problem having MCS start PICKIT Classic.
    The first entry in the setup at Program Filename = PICKit1 Classic.exe
    next the program path = c:\program files\microchip\pickit 1 v2
    next is the parameters. That is the problem
    The classic program will default to the last directory that a hex was loaded from.
    [ALT+F,I]
    will open the file load dialog, but I can not remember how to have it select the file.
    Sorry I was not any help.
  1. Code Folding - Microcode Studio Wish
    By Rob in forum PBP Wish List
    Last Post: - 6th December 2007, 10:11
  2. Microcode studio loader problem
    By woodygjw in forum General
    Last Post: - 10th September 2007, 02:18
  3. Microcode studio and USB pics
    By KPDes in forum mel PIC BASIC Pro
    Last Post: - 27th May 2007, 10:28
  4. New error with MicroCode Studio?
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 20th February 2006, 21:36
  5. How to used ICD of microcode studio
    Last Post: - 19th November 2005, 01:29
