U2270b
Results 1 to 3 of 3
Thread: U2270b
    Mar 2005
    Default U2270b
    I'm trying to get some sense out of the U2270B, I am using Proton and a PIC 16F628A. I need some sample code (manchester) which I can use to test if my circuit is correct, would someone have done this already and maybe be able to help me??
    Many thanks
    Harrison
    Wrong forum. This is the Pic Basic place.
    Hi Harrison,
    Here's the Proton forum: http://www.picbasic.org/forum/ They have a lot of tallented folks
    there that can probably get you up & going.
    Les Johnson (the fellow that created the Proton compiler) published an excellent set of
    Manchester encode/decode routines a while back. They were all in assembler, but easy
    to drop into your BASIC code.
    You might ask while there if he still makes this code available.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. U2270B code
    By aok_1010 in forum General
    Last Post: - 10th November 2006, 19:37
  3. Read atmel u2270b
    By Salutatous in forum mel PIC BASIC Pro
    Last Post: - 8th June 2004, 11:04
