Pulse Width Measurement
Results 1 to 18 of 18
    atomski's Avatar
    atomski Guest
    Question Pulse Width Measurement
    Hello everyone,
    I have an interesting task in front of me and I would
    appreciate your advice. I need to measure pulse widths
    sent by an encoder using a pretty neat way of modulating
    the VCO in an amateur (HAM) radio e.g.
    Hi 200uS, Low 200uS, total = 400uS digital bit "0"
    Hi 200uS, Low 400uS, total = 600uS digital bit "1"
    Hi 200uS, Low 600uS, total = 800uS gives "StartBit"
    Now the tricky part is that a phase shift might occur, thus
    the data might be inverted. The ingenious thing about
    modulating the data in this manner is that anyway you
    send it data will always be the same. I was wondering,
    if it would be better to use PULSIN, RCTIME combination
    in conjuction with couple of IF, THEN statements or maybe
    use the 16F628's CCP module. Any advice would be greatly
    appreciated.
    Sincerest regards,
    YZ7REA Vladimir M Skrbic
    4N7ATV Repeater Administrator
    YU7GHZ Radio Club President
    carl_schell's Avatar
    carl_schell Guest
    Cool
    Atomski -
    Hi. I am not familiar with amerature radio and all of its ins and outs, and am not sure I am clearly understanding what you are doing, but...
    I can tell you that I have used PULSIN commands on regular pins such as PortB pins on 16F877 for frequency measurements and have been able to achieve very nice accuracy down to 10ths of Hz without any problems, (using the CCP pins might be better practice, but for my project they were being used for something else) With the PULSIN command you can measure the High pulse and the Low pulse very easy...
    just keep in mind that the results are in 10-microsecond resolution...so if it says it was high for 20, that means it was high for 20 x 10 micro seconds, therefore ==> High for 200 micro seconds
    Format for PULSIN command is as follows:
    PULSIN Pin, State Variable, Var
    Where:
    State Variable = 1 measures Time Pulse is High
    State Variable = 0 measures Time Pulse is Low
    so...
    PULSIN PortB.1,1,Pulse_High 'State Value of 1 => Measures Time High
    PULSIN PortB.1,0,Pulse_Low 'State Value of 0 => Measures Time Low
    If a 4MHz resomator is used, resolution is about 10 micro-seconds
    Part of my point is that, unless I am misunderstanding what you are doing which is definately possible, I do not see a need to use the RCTIME command, because the PULSIN does such a nice job of measuring the pulses.
    Best of luck to you and let us know what you find out or fill us in on a few more details for those of us lacking knowledge of what you amerature radio guys do! It is very cool to me to see the different kinds of clever projects everybody here is working on. It always serves to inspire me to always work harder, to learn more, to try new projects of my own. I also like the international communications and friendships we are all building! We are doing every day what politicians are incapable of!
    Your friend in the USA
    Carl
    PIC Development Boards with BOOTLOADER
    www.schellelectronics.com
    Novi, Michigan USA
    atomski's Avatar
    atomski Guest
    Carl,
    Tnx for the reply. Well the idea is quite simple. Since radio
    communications don't have the benefit or using wire lines
    and are subjectable to all kinds of RF interference, certain
    so called, modulation techniques have to be employed in
    order to insure "clean" data transfer between two radios.
    With this particular modulation scheme you can actually
    "twist & turn" the RF signal and distort it to the point of
    only couple of dB S/N ratio and still get good data out of
    the demodulator, cuz digital 0 and 1 are represented by
    pulses of different lengths. But let me get to my question,
    as I'm sure the class is anxious to hear it
    I need to do couple of other things while I decode the data
    i.e. measure pulse widths and that's why I was looking into
    CCP module as it can work in the background, undisturbed.
    Another thing, if I use the statement:
    does it mean that PULSIN (high) will wait the timeout
    period, before it does the second PULSIN (low) or it just
    checks both and does it again (providing I put it in a loop)?
    And the last but not the least important. What about the
    timings? How fast PULSIN and CCP hardware really are?
    Can I precisely measure 200uS with either of these?
    Greetings from Novi Sad, Serbia!
    Sincerest regards,
    Atomski, Yes you are right in assuming that the statements will work in sequence. Infact you may lose some of the pulse information as it takes some time for the command to execute. I have used your method of looking at the high and then the low pulse width's for measuring temperature with TMP03 temperature sensors. These output a ratio for temperature change and the signal is continuous. In your case the information to be measured is not continuously the same as each pulse high and low time can possibly be different. I would suggest using the CCP module to do the timing measurements. And to answer the last question, the Pulsin command resolution is a function of the OSC speed. This information should be in your manual.
    atomski's Avatar
    atomski Guest
    Dave,
    how long is the PULSIN command execution time for a 20MHz
    clock? Also, is there an example for CCP under PBP? I'd like to
    try it out. Is it a case of direct addressing with CCP as with
    reading ADC (if ADCIN is not used)? Tnx!
    73!
    Vlad
    Wink
    Hi, Atomski
    I currently use the following lines for that
    PULSIN , input,1, highpart
    RCTIME , input,0, lowpart
    PULSE = Highpart + lowpart + offset
    ( offset is time between falling edge of PULSIN and RCtime measurement beginning )
    ... and I measured offset to be 4 units ( !) at 20 Mhz and 0 at 4 Mhz
    But note you lose the following pulse each time ( PULSIN has always to wait for the next rising edge ...)
    atomski's Avatar
    atomski Guest
    Alain,
    I was just wondering why is it that some use:
    PULSIN, input, 1, Highpart
    PULSIN, input, 0, Lowpart
    and others:
    Is it just a matter of preference or is there some higher
    concept advantage to one of these?
    BTW, when you said that the offset @ 20MHz is 4 units,
    you ment 4 x 200ns, right? Or am I mistaking here?
    I still haven't had time to try this out but I guess the
    following code should work:
    Loop:
    PULSE = (Highpart + Lowpart + Offset) * 10 'pulse width in us
    GOTO Loop
    Wink
    Hi, Atomski
    1) little mistake from me : there's no comma close to PULSIN or RCTIME ...
    so: PULSIN input, 1, value ... is correct writing.
    2) PuLsIn or PULSIN or pulsin are strictly the same for PBP ( and only PBP !!! )
    3) offset is in count units : so, 1 unit is 2µs at 20 Mhz Clock, and 1 unit is 10 µs at 4 Mhz ...
    as far as i can see, you have a 4Mhz clock ... so, offset value is zero : no reason to keep one extra variable !!!
    Your code example will work ( without the comma ...) well, but it reads the high part of the first pulse, and the low part of the SECOND pulse ... generally, it' no problem, but remember it when you have an error detection or use the DEFINE PULSIN_MAX statement - or with non repetitive signals !!!
    atomski's Avatar
    atomski Guest
    Alain,
    I will use 20 MHz clock for my project as I need to use
    FREQOUT statement on same hardware and I need the
    signal to be as smooth as possible.
    Ok, 'bout the comma. I didn't notice the error either...
    I actually don't need that much accuracy when I come to
    think of it bacause digital zero is represented with 400us,
    digital one with 600us and startbit with 800us so I could
    use a couple IF, THEN statements to convert pulses to bits.
    For example:
    Loop:
    PULSIN input, 1, Highpart
    PULSIN input, 0, Lowpart
    PULSE = (Highpart + Lowpart) * 10 'pulse width in us
    IF PULSE > 700 THEN Loop ' If startbit capture again
    IF PULSE < 500 THEN Rxd = 0
    IF PULSE > 500 AND PULSE < 700 THEN Rxd = 1
    GOSUB Send_Data
    GOTO Loop
    ... or something like this
    Sincerest regards,
    Atomski,
    Like Alain said "But note you lose the following pulse each time ( PULSIN has always to wait for the next rising edge ...)" this also takes place when you change the state and once again issue the PULSIN command. I don't beleive this scheme will work for what you are trying to accomplish. I beleive you will have to use the CCP module directly, preferably with interrupts to capture the waveform timings you require for decoding. To answer your question, there is NO support in PBP for the CCP module when using it for waveform timing. Only PWM output.
    Wink
    Welcome, dave ...
    There might be a joke: the Hi 200 µs part is always the same value ...so, may be it is not compulsory to MEASURE it, just verify its presence ... ( no change for 150µs, for instance ...)
    a simple PULSIN input, 0, value could do the work ... and catch all the incoming pulses !!!
    a small mistake, in the lines:
    as resolution is 2µs @ 20 Mhz ... you should write:
    PULSE = (Highpart + Lowpart) * 2 'pulse width in us
    atomski's Avatar
    atomski Guest
    Nice one Alain! I'll give it a try. I like the way you think
    Vlad
    Talking
    Hé, Hé,
    Thinking simple is always the best way ...
    atomski's Avatar
    atomski Guest
    Guys,
    The project id developing just fine. I have written both
    the encoder and decoder software for 16F628 and it
    looks sweet. However, I still have some minor problems
    to address and hopefully I'm going to solve this in the
    next couple of weeks. I'd like to thank all of you who
    helped me!
    atomski's Avatar
    atomski Guest
    Ok, here I am again.
    Alain, I have a little problem with your measurement method.
    For example, if I just verify the presence of high pulses
    and measure low pulses, everything works just fine until
    the phase shift in the signal occurs. Then my high pulse
    becomes low pulse and vice versa. I really need to
    measure both high and low pulses. The problem is that if
    I use two consecutive PULSIN statements it doesn't work.
    For example:
    PULSIN Rx_Pin, 1, Pulse_Hi
    PULSIN Rx_Pin, 0, Pulse_Lo
    First PULSIN waits the rising edge and measures the
    period that pin stays in that state, right? The second
    PULSIN waits for the falling edge and repeats the process
    for low pulse. Well I'm running my pic 16F628 @ 20MHz
    and it seems to be missing the falling edge after
    measuring Pulse_hi. Any ideas? Maybe if I used a
    combination of PULSIN and RCTIME this might not happen?
    If I understand the manual correctly RCTIME measures
    the state of the pin right after the statement has been
    issued in the program. That way the pic doesn't need to
    detect the falling edge, right?
    PS Is there a way to toggle between rising/falling edge in
    a single PULSIN statement? For example:
    Edge Var Bit
    Edge = 0
    IF Rx_Pin = 1 Then : Edge = 1
    PULSIN Rx_Pin, Edge, Pulse
    Lightbulb
    Hi, atomski
    You're a bit hard with me ...
    So, you have to create a "rectifier" stage with a bit of analog and logic circuits before the PIC; see:
    Consider half of the pulse voltage, and make a, say precise 50µS, positive pulse at each crossing, pos or neg ...
    then, you can use PULSIN as it will be "resettable" during the 50µS pulses ... then add 50µS to what you've measured.
    Just program what to do if two identical values follow each other ( it's then a phase shift ...)
    Cheeeeeese, you're on the pic' !!!
    atomski's Avatar
    atomski Guest
    Good idea mate, I'll give it a thought. I have something else
    in the works to solve this problem. I'll keep you all posted...
    If anyone has anything interesting to propose, I'm all ears!
    Thanks!
    Puerto Rico
    Talking Hello
    what type of pulse you goint to read...
    if Rc then
    DEFINE PULSIN_MAX 6000 '6000 Define the Pulsin time
    PulsIn Throtpin, 0, Throttle
  1. PBP projects for R/C models
    By malc-c in forum Code Examples
    Last Post: - 21st October 2016, 12:56
  2. Pulse Capture and byte building
    Last Post: - 21st July 2009, 01:59
  3. Pulse width modulation
    By manxman in forum General
    Last Post: - 2nd March 2006, 12:06
  4. PIC12f675 timer1 pulse width
    By ck1223 in forum mel PIC BASIC Pro
    Last Post: - 15th February 2006, 04:05
  5. pulse width modulation
    By cheznez in forum mel PIC BASIC Pro
    Last Post: - 16th February 2005, 17:14
