Unless redefined, the default OSC speed is 4MHz. If you use a 125kHz Xtal instead of 4MHz, then you can adjust by the ratio
4,000,000/125,000=32
For example:
With a 4MHz Xtal a one second pause would be
With a 125kHz Xtal, a one second pause (approx) would beCode:PAUSE 1000
Code:PAUSE 31 ' =1000/32
