Serout format
Results 1 to 4 of 4
Thread: Serout format
    Apr 2007
    Question Serout format
    This is in reference to the example:
    http://www.rentron.com/four-channel-ad.htm
    In this example of Analog-Digital conversion what is the format of RESULT[X]
    that is sent to the computer serial port ? i.e. binary or ascii ?
    SEROUT GPIO.5,N2400,[1,RESULT[0],2,RESULT[1],3,RESULT[2],4,RESULT[3]]
    Unsure of the format, if I put # like:
    SEROUT GPIO.5,N2400,[1,#RESULT[0],2,#RESULT[1],3,#RESULT[2],4,#RESULT[3]]
    will the result to PC serial port be in ASCII format ?
    I would like to get it in ASCII format.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    I believe the examples on Bruce's website are sending data through the serial port to a VB written application that does the ASCII conversion, not to hyperterminal.
    If you want to send to hyperterminal (examples)
    X = 65
    Serout GPIO.5,N2400,[65] 'sends "A" to hyperterminal
    Serout GPIO.5,N2400,[#65] 'sends "6" and then "5" to hyperterminal
    Serout GPIO.5,N2400,[X] 'sends "A" to hyperterminal
    Serout GPIO.5,N2400,[#X] 'sends "6" and then "5" to hyperterminal
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    From the manual for more clarification..
    SEROUT supports three different data types which may be mixed and
    matched freely within a single SEROUT statement.
    1) A string constant is output as a literal string of characters.
    2) A numeric value (either a variable or a constant) will send the
    corresponding ASCII character. Most notably, 13 is carriage
    return and 10 is line feed.
    3) A numeric value preceded by a pound sign ( # ) will send the
    ASCII representation of its decimal value. For example, if W0 =
    123, then #W0 (or #123) will send “1", “2", ”3".
    Apr 2007
    Default MScommctl
    VB Commctl has this binary input which I have never used.
    Will do experiment and post here.
    Rentron's(Bruce) examples are great--I could not find other website with that quality of examples.
    Thanks for the info.
    Aftab.
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
    Last Post: - 13th December 2008, 18:11
  4. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
  5. Replies: 11
    Last Post: - 13th July 2005, 20:26
