HELP !!! How change the voltage of a pin ????
Results 1 to 7 of 7
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Many PICs have onboard Voltage Reference Modules (See the 16F628A for example). With this PIC for example, you can output the reference voltage on RA2 (and use an external buffer if and as necessary). You can get between 4.5 and 5 Bit resolution depending on the segment selected. See the Voltage Reference Module section of your PIC's datasheet.
    For the 16F628A, you can output (assuming VDD = 5.00V)
    0-3.125V by 0.15625V intervals
    0-3.594V by 0.20833 intervals
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Mar 2005
    Mandalay,Myanmar
    Default Check sine function & frequency out function
    One of PBP build in maths functions is sine.
    This mean PIC pin can generate time dependent voltage.
    So by means of software pwm(***pbp build in function) technique you can get any analog volt between 0 volt and 5 volt.
    To get smooth voltage you should use passive low pass filter.(R & C series )
    from_myanmar
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 19:20
  3. Microcontroller with 2 way paging application problem
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
  5. Grounding Negative voltage through I/O pin
    By Squibcakes in forum Schematics
    Last Post: - 31st July 2006, 12:12
