HELP !!! How change the voltage of a pin ????
Results 1 to 7 of 7
Threaded View
  1. #7
    Jul 2007
    Question I2C vs SPI
    Quote Originally Posted by sayzer View Post
    Allow me to recommend MCP4921 DAC for easier and less complex control.
    Hi Sayzer,
    MCP4921 is using SPI instead of I2C. I tought I2C, which I'm currently using, was easier than SPI because PBP has I2CREAD and I2CWRITE commands. I saw example of SPI slave & master on melabs website, but I can't see why you said MCP4921 was easier. Can you elaborate?
    J-P
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 20:20
  3. Microcontroller with 2 way paging application problem
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
  5. Grounding Negative voltage through I/O pin
    By Squibcakes in forum Schematics
    Last Post: - 31st July 2006, 13:12
