Button press and press & hold how to ?
Results 1 to 10 of 10
    Jun 2007
    Germany
    Hello grandpa,
    Maybe this can be good for you.
    Button VAR PORTB.0 ' Your Input switch
    Loop    VAR WORD
    InputButton:
    IF Button = 1 THEN Check4Button
    GOTO InputButton
    Check4Button:
    FOR Loop = 0 TO 1000 ' 1 Second
         PAUSE 1
         IF Button = 0 THEN Stop ' If button was released before 1 Sec = short keypress
    NEXT Loop
    IF Button = 1 THEN Park ' If button was hold longer than 1 Sec = long keypress
    GOTO InputButton
    Stop:
    ' Here is your code
    Park:
    ' Here is your other code
    regards Rob
    Jun 2007
    Hi Grandpa,
    As you use push switch, don't forget to debounce it
    Johan
    Jan 2006
    Istanbul
    Quote Originally Posted by Robson View Post
    Hello grandpa,
    Loop    VAR WORD
    InputButton:
    GOTO InputButton
    Check4Button:
         PAUSE 1
    NEXT Loop
    GOTO InputButton
    Stop:
    ' Here is your code
    Park:
    regards Rob
    Something to pay attention for:
    Button and Stop are reserved words =>> they are commands.
    You may want to rename them as Btn and Stp.
    Jun 2007
    Germany
    Oh of course. How I forget it ;-x
    Maybe it was too late 4 me ...
    Btn VAR PORTB.0 ' Your Input switch
    LoopTime VAR WORD
    InputButton:
    PAUSE 20 ' Button delay or use DEFINE BUTTON_PAUSE before
    IF Btn = 1 THEN Check4Button
    GOTO InputButton
    Check4Button:
    FOR LoopTime = 0 TO 1000 ' 1 Second
        PAUSE 1
        IF Btn = 0 THEN Stp ' If button was released before 1 Sec = short keypress
    NEXT LoopTime
    IF Btn = 1 THEN Park ' If button was hold longer than 1 Sec = long keypress
    GOTO InputButton
    Stp:
    ' Here is your code
    Park:
    Jul 2007
    Grass Valley CA
    Check4Button:
    PAUSE 1
    NEXT Loop
    GOTO InputButton
    Stop:
    ' Here is your code
    Park:
    [/code]
    regards Rob
    I'm a real newbie at the PIC, but my BASIC is fairly decent. What is the reason for the GOTO InputButton command at the end of the FOR-NEXT loop? The button will be either zero (in which case you GOTO Stp) or one (in which case you GOTO Prk). How would the code ever get to that GOTO InputButton command? Or is that a belt-and-suspenders command on the off chance that the button is released during the last millisecond of the loop?
    Somebody said something about switch debounce. Is there a standard debounce code snippet for pushbutton switches? A 50 millisecond delay waiting for the sucker to stop clanging around?
    Jim
    Hello Everyone. I use a similar system on a voice record circuit. The record button works as a record button but if pushed and held without making a recording, it resets the voice record chip to a preset address at the beginning of memory. Snippets of code below. Perhaps you could use this system for your circuit.
    'PORTB.0 IS THE RECORD BUTTON, 0 = PUSHED, 1 = RELEASED
    'PORTB.1 IS MESSAGE BUTTON, 0 = PUSHED, 1 = RELEASED
    IF PORTB.0 = 0 AND PORTB.1 = 0 THEN RECORD 'RECORD MESSAGE
    IF PORTB.0 = 0 AND PORTB.1 = 1 THEN RESETMESSAGES 'RECORD BUTTON PUSHED ALONE
    RECORD:
    DOES THE RECORD FUNCTION
    RESETMESSAGES:
    IF PORTB.0 = 0 AND PORTB.1 = 0 THEN RECORD 'CHECK IF BOTH ARE PUSHED BEFORE 3 SECONDS
    LET RESETTIMER = RESETTIMER + 1
    Pause 100
    IF RESETTIMER >= 30 Then MAKESOUND 'MAKES BEEP AFTER 3 SECONDS AND CONTINUES PROGRAM
    IF PORTB.0 = 0 THEN RESETMESSAGES
    IF PORTB.0 = 1 THEN START 'BUTTON RELEASED GOTO START
    Jun 2007
    Germany
    Quote Originally Posted by weirdjim View Post
    Jim
    1. GOTO InputButton is for start at the beginning after the button was detected as pressed. Going to Loop the program
    2. If the button was released before the timer ends at 1 second means -> short press of the button.
    3. ELSE long press of button.
    4. Insert a pause of 20ms -50ms. My best results measured with 20ms for Button debounce.
    If you have a complex matrix of columns and rows with double action feature like this, your code will slow down. I also prefer to use for next loops with Pause 1, while time critical projects and Interrupt routines.
    If you insert
    PAUSE 2000 is it impossible to jump to the Interrupt routine, when your pause is active.
    Delay2: ' Now it´s possible to interrupt during the PAUSE and jump to your Interrupt location
    FOR x = 0 TO 1000
    PAUSE 1
    NEXT x
    I mean that are my techniques, everyone should code like he likes it.
    Jul 2007
    Smile I'm learning something here
    Hi Robson,
    you said: "PAUSE 20 ' Button delay or use DEFINE BUTTON_PAUSE before"
    I tought before that DEFINE BUTTON_PAUSE was used only by the BUTTON command. Now, from what you wrote is that correct to say that BUTTON_PAUSE will put a debounce delay on all PIC inputs pins?
    J-P
    Jun 2007
    Jim
    You can use software debounce ( with Button command ) , but if you dont want to change the code, just put the switch in parallel with a resitor and capacitor, something like this:
               sw
        -------_-------
        --vvv----||----!
           R        C
  1. 4 Bytes one button press
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 15th January 2010, 23:36
  2. Giving power to MCU upon button press - Good Idea?
    Last Post: - 21st July 2009, 08:34
  3. multi functions button press
    By malwww in forum mel PIC BASIC Pro
    Last Post: - 27th May 2009, 01:12
  4. Using Sleep
    Last Post: - 17th August 2008, 05:05
  5. Sleep until button press?
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 9th October 2007, 04:47
