Picbasic Newbie Problem
Results 1 to 5 of 5
    What version of PBC are you using? It compiles fine with v1.45.
    Can you compile any of the examples in the SAMPLES folder that
    poke values to TRIS registers?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2007
    Germany
    Hello Stargazer
    what should this code do?
    Are you looking for how to display the outputs from PORTB connected with LEDīs?
    My compiler returns an error too.
    Maybe this one will help you
    TRISB = 0
    B0 VAR BYTE
    Loop:
    FOR B0 = 0 TO 255
        PORTB = B0
        PAUSE 250
    NEXT B0
    GOTO Loop
    Default thanks for the help
    Thanks!
    I am just trying to troubleshoot my compiler - picbasic ver1.41.
    I noted from the ME labs website that the PEEK and POKE were added on version 1.20, so they should be working on my version. I do not see any syntax error or typos.
    Version 1.41 is fairly old. Look at this page to see if the PIC you're compiling for is supported
    by version 1.41: http://www.microengineeringlabs.com/...pgrade.htm#pbp
    If not, that's probably the error.
    -Bruce
    tech at rentron.com
  1. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  2. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
  3. Problem on writing EEPROM in Winpic800 with picbasic pro
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 17:33
  4. PicBasic Pro Math Problem??
    By Glen65 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 05:36
  5. DMX & PicBasic coding problem
    By magicmarty in forum mel PIC BASIC Pro
    Last Post: - 20th September 2004, 16:35
