ULPWU & PLVD on 12F635 & 16F684
Results 1 to 19 of 19
    Question
    Hi Bruce, thanks for replying. This is how I am doing now:
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_ON & _BOD_OFF & _CPD_ON & _IESO_OFF & _FCMEN_ON & _WUREN_OFF
    OSCCON = %01100000 ' Internal 4MHz select
    OPTION_REG = 0 ' internal pull-ups on/off according to value written on port
    CMCON0 = 7 ' disable comparator
    VRCON = 0 ' disable internal Vref
    GPIO = %00000000 ' LED off on boot
    TRISIO = %011001 ' GPIO.0 / 3,4= input, rest outputs
    PIR1 = 0 ' clear peripheral int flags
    PCON.5 = 1 ' ultra low power wakeup enabled
    Include "modedefs.bas"
    GPIO.0= 1 ' set data latch on GPIO.0
    TRISIO.0= 0 ' GPIO.0 = output (charging cap)
    PAUSEUS 100 ' charge cap for 1
    TRISIO.0= 1 ' GPIO.0 = input to discharge cap
    IOCA.0= 1 ' int on change enabled for GPIO.0
    IOCA.4=1 ' int on change enabled for sensor @ GPIO.4
    while gpio.4 : wend
    INTCON= %00001000 ' global ints disabled, int on change enabled
    @ SLEEP ' put PIC to sleep
    GOSUB Test ' go test for under voltage condition AND send data if pin is made high by sensor
    GOTO Main
    Though the code is working fine for now, I would still like an opinion if the above way of doing this is the reliable way in long term.
    Thanks again
    What exactly is it you're trying to do?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Post
    I am trying to build an PIR sensor with PIC attached. My aim is to make PIC sleep and wake up like every few seconds or minutes (Which I know will be based on Res/Cap value on GPIO.0) and check for voltage OR wake up if the sensor makes its pin go high.
    I see. If it's battery powered, then you don't want to waste current with internal pull-ups,
    and you don't want one on GPIO.0 connected to the internal ULPWU current sink.
    You want GPIO.0 to charge the cap through the series resistor, go to input, and let the cap
    discharge through the internal current sink. Kind of defeats the purpose if you have the pin
    held high via the internal pull-up.
    And, if your sensor outputs logic 1 when active, you should probably avoid the while GPIO.4
    since it's detecting something when GPIO.4 = 1.
    A better approach might be to read the port immediately on wake-up, find out which pin
    caused the interrupt on change wake up, then jump to a routine to handle it.
    Maybe something like this?
    OPTION_REG.7 = 1 ' turn off current hog internal pull-ups
    TRISIO = %011000 ' GPIO.0 / 3,4= input, rest outputs
      IF GPIO.4 THEN HandlePIR ' goto PIR detect routine
      INTCON= %00001000 ' globals disabled, int on change enabled, clear wake up int flag bit
      IF GPIO.4 THEN
        PCON.5 = 0 ' disable current sink on ultra low power wakeup
        GOTO HandlePIR ' if PIR sensor woke us up, handle it
      GOTO Main
    -Bruce
    tech at rentron.com
    Post Thanks a lot
    Thanks Bruce. I am going to take your advice as it exactly was my aim towards increasing battery life. Thanks again
    You're welcome, and good luck. Have a look at this when you have time.
    It has several good tips on power savings for battery apps:
    http://ww1.microchip.com/downloads/e...doc/41200B.pdf
    And this one too: http://www.ac-limoges.fr/sti_ge/IMG/...C_nanowatt.pdf
    Also take a peek in the Electrical Specifications section of the data sheet.
    It shows current required for various peripherals, oscillators, etc..
    -Bruce
    tech at rentron.com
    Default Current consumption?
    Hello Bruce, can you tell me what is the lowest current consumption you have achieved with 12F635?
    The minimum I have is 320uA, using external 4MHz resonator. which I don't know is a lot or reasonable? Thanks
  1. 16F684 Basic Functionality
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 30th September 2009, 20:28
  2. ICSP and 16F684
    By onaclov2000 in forum Schematics
    Last Post: - 5th March 2009, 17:31
  3. help with HPWM on 16f684
    By kimvellore in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2006, 08:05
