How to convert HEX Value as formatted BIN String ?
Results 1 to 6 of 6
    Jun 2007
    Germany
    Darrel you are amazing ;-)
    Only one small bug is inside
    the first step will not recognize as show below i used AA 3 times = 1010101010101010
    my watching LED is blinking 1st time but no flashing on remote ?
    It seems that the PIC eats up the first bit. And at last the remote should be off but itīs always on. Looks like shifted one bit.
    I tried something but cannot find where the problem is.
    lp var byte
    remote var PORTB.5
    TempB   VAR BYTE
    BitLoop VAR Byte
    ledstepper var PORTB.4 ' Control each step
    remote = 0
    LEDSTEPPER = 0
    FOR lp = 0 TO 2
    LOOKUP lp,[$AA,$AA,$AA],TempB
    FOR BitLoop = 0 to 7
    remote = TempB.0[BitLoop]
    Pulsout ledstepper,1000
    NEXT BitLoop
    next lp
    Instead the sequence looks like that:
    ledstepper : 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0
    remotepin : 0 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 1
    Jun 2007
    Germany
    I got it.
           FOR BitLoopH = 7 to 0 step -1
               remote = tempb.0[bitloopH]
           NEXT BitLoopH
    Thanks Darrel, sometimes is it good to try some things by myself. That was really bad to use $AA as testbyte. ;-)
    The string comes from the last position.
    Ah Ha! MSB first.
    I should have seen that.
    Great, glad you figured it out.
    regards,
    Jun 2007
    Germany
    @Darrel
    thatīs really fantastic. Iīve shrunked my data code about the strings from 2,7kB to :
    just listen 195 "BYTE" using the Eeprom now. Not the complete program but only the data space, which tooks a lot of memory. It was not possible before to store that whole data on the eeprom. But with this great snip of code, knowing now to realize for coming projects, can i save a hugh amount of space of my lovely PIC ;-)
    I just canīt believe it now.
    One complete string takes 31 byteīs of the eeprom space. I have 8 instructions to send by pressing a key.
    Only for demonstration :
    volume-:
    a = 0
    gosub loop
    volume+:
    a = $20
    gosub loop
    undershort:
    a = $40
    gosub loop
    underlong:
    a = $60
    gosub loop
    sourceleft:
    a = $80
    gosub loop
    sourceright:
    a = $A0
    gosub loop
    scrollup:
    a = $C0
    gosub loop
    scrolldown:
    a = $E0
    gosub loop
    loop:
    b = a + $1D
    FOR lp = a TO b
    read lp, tempb
               remote = tempb.0[BitloopH]
               pauseus 660
           NEXT BitLoopH
    next lp
    PORTB.4 = 1 ' Control LED if sequence finished
    PORTB.4 = 0
    Maybe i forgot something ...
    But itīs still working... So i donīt forget something :-)
    Big thanks to YOU
  1. How to convert a HSERIN string to a hex value?
    By ShortBus in forum mel PIC BASIC Pro
    Last Post: - 22nd October 2009, 04:41
  2. Converting Dec word to Hex string
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 05:44
  3. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 04:39
  4. Convert dec/binary to Hex
    By SagemFree in forum mel PIC BASIC Pro
    Last Post: - 11th May 2005, 18:00
  5. hex to bin converter
    By darkman in forum mel PIC BASIC Pro
    Last Post: - 27th April 2005, 14:41
