Blink without the pause command
Results 1 to 9 of 9
    I'm using a pic 12F683 (internal oscillator) to turn on/off some lights on my R/C car...
    I'm reading the output from the receiver with pulsin and then I can turn on/off the lights...
    I'm using the pwm output to control the stop lights... Normally, they are 50% lit and when I hit the brakes they go 100% brightness...
    Also, I want to blink two yellow LEDs as turn lights, but I cannot wait while the LEDs are blinking because I need to know if something else happens, like hitting the brakes....
    So, that's why I wanted to know how to blink the LEDs without the pause command...
    I think I could do something with the "ifs", but as you said Bruce, will have to recalibrate the code...
    Thanks for your answers!
    Daniel.
    I would go with Darrel Taylors' instant interrupts with timer1. Disable interrupts before using
    PULSIN. Then re-enable them after PULSIN. A few mS either way shouldn't be a big deal for
    a heart-beat type LED on/off.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Lightbulb
    Hi, Daniel
    the easy way with R/C signals ...
    the servo signal is THE "missing timer" ... say the 1.5 ms is @ 40 Hz ( example )
    if you want to blink @ 2Hz ...
    just count the incoming 1.5 ms pulses and TOGGLE the led output for COUNT // 10 = 1,or 2 ... but not 0
    takes very little CPU time.
    hé,hé ...
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 07:28
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. Replies: 11
    Last Post: - 12th July 2008, 03:36
  4. Fade out LEDs question
    By Sam in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2008, 11:50
  5. Help Quick Need to make code smaller
    By Programmednew in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 04:46
