Blink without the pause command
Results 1 to 9 of 9
    Question Blink without the pause command
    Hi All,
    I want to blink a LED without the pause command because I want to do other things and not stop the entire loop every time the LED blinks.
    For example, with the pause command the code looks like this:
    high portb.0
    low portb.0
    Without the pause command the code could look something like this:
    count_on var byte
    count_off var byte
    pause_led var byte
    count_on = 0
    count_off = 0
    pause_led = 5000
    if count_on = 0 then
    high portb.0
    if count_on != pause_led
    count_on = count_on + 1
    if count_on = pause_led then
    low portb.0
    count_off = count_off + 1
    if count_off = pause_led then
    count_on = 0
    count_off = 0
    goto main:
    My question is, if I want to leave the LED turned on for 1 second, how many "if" cycles should I do?
    Thanks!
    Daniel.
    One thing and one thing only can be done at a time, that is until parallel or "quantum" computers hit the market.
    You will want to look at "interrupts" . That is how the impression of doing more than one thing at a time is accomplished. Even your desktop with all of the ram and cpu speed can only do one thing at a time - believe it or not.
    http://www.picbasic.co.uk/forum/show...ght=interrupts
    Look at the above link for a slick way of using interrupts with PICs or the manual for the old fashion way.
    I agree with Dave. But the approach to take really depends on what it is you need to do in
    between the LED on\off periods, how long the LED should be on AND off, the oscillator speed,
    and which PIC you're using.
    Trying to work out the number of if-thens between toggling the LED on or off isn't a very
    good approach, since the time will vary as your code in between the on\off periods will
    change, and require recalibration with every change.
    More information would really help folks here to help you..;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2006
    Istanbul
    Another way would be to use a timer module.
    You can check the timer overflow bit and increment a variable at each overflow.
    Then, you can ON and OFF the LED at any desired time using this variable.
    I'm using a pic 12F683 (internal oscillator) to turn on/off some lights on my R/C car...
    I'm reading the output from the receiver with pulsin and then I can turn on/off the lights...
    I'm using the pwm output to control the stop lights... Normally, they are 50% lit and when I hit the brakes they go 100% brightness...
    Also, I want to blink two yellow LEDs as turn lights, but I cannot wait while the LEDs are blinking because I need to know if something else happens, like hitting the brakes....
    So, that's why I wanted to know how to blink the LEDs without the pause command...
    I think I could do something with the "ifs", but as you said Bruce, will have to recalibrate the code...
    Thanks for your answers!
    Daniel.
    I would go with Darrel Taylors' instant interrupts with timer1. Disable interrupts before using
    PULSIN. Then re-enable them after PULSIN. A few mS either way shouldn't be a big deal for
    a heart-beat type LED on/off.
    -Bruce
    tech at rentron.com
    Lightbulb
    Hi, Daniel
    the easy way with R/C signals ...
    the servo signal is THE "missing timer" ... say the 1.5 ms is @ 40 Hz ( example )
    if you want to blink @ 2Hz ...
    just count the incoming 1.5 ms pulses and TOGGLE the led output for COUNT // 10 = 1,or 2 ... but not 0
    takes very little CPU time.
    hé,hé ...
    Bombay, India
    Quote Originally Posted by danielhr77 View Post
    SNIP
    count_on var byte
    count_off var byte
    pause_led var byte
    count_on = 0
    count_off = 0
    pause_led = 5000
    high portb.0
    low portb.0
    count_on = 0
    count_off = 0
    goto main:
    Daniel
    I can suggest (without interrupts) the following
    counter:  var   word
    Led:        var   PortB.0
    counter =0
    main:   if counter < HalfSecondValue then
                counter=counter+1  ' increment the counter
                counter = 0
                Led = !Led      ' toggle every half second
             '  do whatever you have to do here
            goto main           ' go back to the top
    Here, HalfSecondValue is something you will have to determine either by counting the machine cycles or experimentally(easier)
    Jerson
    Thanks to all for your help!
    I also found this from Darrel: http://www.darreltaylor.com/DT_INTS-18/blinky.html
    Regards!
    Daniel.
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 06:28
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  3. Replies: 11
    Last Post: - 12th July 2008, 02:36
  4. Fade out LEDs question
    By Sam in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2008, 10:50
  5. Help Quick Need to make code smaller
    By Programmednew in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 03:46
