PIC18 (452) DATA or EEPROM Command
Results 1 to 4 of 4
    Unhappy PIC18 (452) DATA or EEPROM Command
    Hi everybody,
    A small surprise this afternoon with a 18F452 :
    Clearing ( With 0s ) locations in the EEPROM gives such results ...
    DATA (0), 0 (10) ... writes 10 Times 0 from location 0 to 09 ... quite normal !!!
    but
    DATA (1), 0 (10) ... writes 11 Times 0 from location 1 to location ...0B or 12 !!!
    EEPROM equivalent Command gives exactly the same result ...
    Not THE big bug ... , but take care when presetting EEPROM values ...
    It's not actually a bug. The block write size to EEPROM is done in blocks of two bytes,
    so when you have an odd number of bytes, the most significant byte written will be 0.
    If you change DATA (1), 0 (10) to DATA (1), 1 (10) you'll see how the msb is 0, and you
    have only 10 1's actually being written.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Unhappy
    Hi, Bruce
    Thanks for the reply ...
    If I undestood it , in your example there's Always 11 Writes: 10 "1"'s and 1 x "0" ... The original "FF" @ Loc. 12 is then overwritten by a "0"
    Hi Alain,
    With DATA (1), 0 (10). Skip location 0 then write 10 0's. The total is 11. 1 byte skipped, and
    10 bytes to be written.
    PBP produces asm that looks like this;
    ORG EEPROM_START + 00000h
    DW 0000000FFh ' locations 0 and 1. Note FF is the skipped location 0.
    DW 000000000h ' locations 2 and 3
    DW 000000000h ' location 4 and 5
    DW 000000000h ' locations 6 and 7
    DW 000000000h ' locations 8 and 9
    DW 000000000h ' locations 10 and 11
    Which looks like this in EEPROM;
    0000- ff 00 00 00 00 00 00 00
    0008- 00 00 00 00
    DW defines a data word, so each word is made up of two bytes. If you write an odd number
    of bytes, the most significant byte will be cleared because DW forms everything as a word
    value. On the 18F series, program memory (where EEPROM is) is all word aligned.
    It's a bit easier to see if you do something like this;
    DATA 1,2,3,4,5,6,7,8,9
    Which produces;
    DW 000000201h
    DW 000000403h
    DW 000000605h
    DW 000000807h
    DW 000000009h
    And in EEPROM it looks like this;
    0000- 01 02 03 04 05 06 07 08
    0008- 09 00 <-- note the msb here is 0
    You just have to remember that there will always be an even number of bytes written to
    EEPROM. The 18F reference manual shows how this works.
    -Bruce
    tech at rentron.com
  1. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 02:46
  2. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  3. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  4. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 19:42
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
