ASM equiv for SERIN2???
Results 1 to 3 of 3
    Oct 2003
    Australia
    Default ASM equiv for SERIN2???
    I think I need to speed up my program by using ASM.
    Basically I have a PIC programmed as a DCE using Hardware flow control, it then prints out to a centronics printer.
    My flow control (Using DSR and CTS) from the PIC works ok but when the flow speed is increased, the PIC fails to print some characters...
    Here is a cut from the code: (CTS - Clear to Send)
    MAIN:
    HIGH CTS
    SERIN2 SDI,16780,[char]
    LOW CTS
    <... output to printer here ....>
    GOTO MAIN
    It seems that the pic is not quick enough between capturing the char and clearing the CTS signal.
    I may be able to speed things up by converting the above three lines to ASM?
    Can anybody help please?
    J
    Oct 2003
    Cyprus
    Hello Squibcakes,
    First, avoid the commands: High <pin> and LOW <pin>.
    Use CTS=1 or CTS=0 instead. The take less code space and I thing they execute faster. There is an assembly equivalent of just few lines but I do not use assemble and need to read the manual to answer this.
    Secondly, you might try the HSERIN and HSEROUT commands if your PIC has a hardware USART build-in. This might need a MAX232 IC to invert the logic.
    K.
    Oct 2003
    Australia
    Hi Kypros,
    Thanks for the HIGH / LOW tip...
    I've been playing around with the code some more and found that it is even better to use the FLOW pin option.. ie
    SERIN2 SDI\FLOW,16780,[char]
    and scrap the HIGH , LOW flow commands all together.
    Its possible that the PC's UART buffe is still causing me some problems and headaches....
    I may need to re wire and use the USART after all.... I will post here if I have any success.
    Squib
  1. PBP, ASM and LST files
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th January 2010, 13:43
  2. ASM help
    Last Post: - 21st October 2009, 03:08
  3. Serial Output - for an ASM numb
    By scomi85 in forum Serial
    Last Post: - 1st March 2009, 10:13
  4. Problem using ASM instruction
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2008, 15:26
  5. Can an asm interrupt contain gosub to a picbasic routine?
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 21st April 2005, 19:49
