16F88 reading Analog Input
Results 1 to 3 of 3
    thunderstrike44's Avatar
    thunderstrike44 Guest
    Default 16F88 reading Analog Input
    I have used the 16F877 PIC Processor for about a year and I have a little project I wanted to use the 16F88 for. I am having problems reading the analog inputs, I think. I have setup for only AN0 and AN1 to be analog in and am setting Port b 0-3 as indicators to see voltage level vdd-vss. Here is my testing code but I can't see to get it to work.
    DEFINE LOADER_USED 1
    OSCCON = %01100111
    TRISA = %00000011
    TRISB = %00000000
    PORTB = %00000000
    ANSEL = %00000011
    ADCON1 = %10000000
    CMCON = 7
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    CTA VAR BYTE
    ADCIN 0, CTA
    ledtst1:
    IF CTA > 50 Then tst2
    PORTB = %00000001
    GoTo cont
    tst2:
    IF CTA > 125 Then tst3
    PORTB = %00000011
    GoTo cont
    tst3:
    IF CTA > 200 Then tst4
    PORTB = %00000111
    GoTo cont
    tst4:
    PORTB = %00001111
    cont:
    Pause 10
    GoTo main
    It does not give me any errors nor does it work. I am using MELabs Pro Basic compiler version 2.44. I have ordered the 2.45 but have not gotten it yet.
    Any sugguestions?
    Brian
    paul farrugia's Avatar
    paul farrugia Guest
    Default 16F88 Analogue inputs
    I,ve not used it either but a quick scan of the datasheet seems to show that ADCON0 must also be set?
    Cheers
    Paul
    Default 16F88 Analog Reading Problem
    Tried that also to no avail. I don't know why they have to change the structure so much for one chip. I have been using the analog inputs on the 16F877A with out a problem, but the bugger is really different. There must be a answer.
    Brian R.
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. Analog Input on PIC16F88
    By penelopepug in forum mel PIC BASIC Pro
    Last Post: - 6th May 2008, 23:49
  3. 16F88 Analog In
    By Mugelpower in forum mel PIC BASIC Pro
    Last Post: - 25th March 2008, 09:30
  4. 16f88 - pin RA4 as analog input
    Last Post: - 15th December 2006, 14:55
  5. Analog pins for digital input
    Last Post: - 9th September 2005, 01:32
