18f242 reset
Results 1 to 8 of 8
Thread: 18f242 reset
    Apr 2007
    Quote Originally Posted by Armadus View Post
    Bob,
    Thanks for the reply. I do have a cap across +5 and Gnd. The program is simply
    High PortC.1
    YR:
    Low PortC.1
    High PortC.2
    Pause 700
    Low PortC.2
    Pause 700
    goto YR
    I do have the WDT enabled
    It will generally run for about 5 minutes, but sometimes only a few cycles, and resets to High PortC.1.
    I am using a 7805 regulator, well filtered.
    I have been working on the theroy that the power supply is dropping out, but it always appears to be at full power.
    Do you have a diode across the relay coil to suppress the back emf? If not, the "spike" when the relay is switched off could be causing the pic to reset.
    Andy
    Sep 2005
    Default 18f242 reset
    Andy,
    There is a diode accross the relay.
    Try replacing the transistor with a LED and a 470 ohm resistor to make sure it is not something to do with the transistor or relay.
    Is the cap across power rails large enough for BOR fuse. Rule of thumb, LED with resistor across power rails should go dim not instant off when power is cut.
    What have you done with MCLR?
    Sep 2005
    Dave,
    1. I have replaced the transistor and relay, but made no difference. I will try the resistor and LED you suggested.
    2. I have a 330uF cap between the output of the regulator and Gnd.
    3. MCLR pin is connected to +5 via a 4.7K series resistor, and a 0.1uF cap to gnd.
    One more thing if the other does not get it. Tie all un-used pins to ground with a 10k or so. If there is "noise" could have something to do with it. Good to do this on finished projects.
  1. IC12F508 with Internal Oscillator and Software Reset
    By karan123 in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2009, 16:13
  2. pic reset sometimes
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2008, 17:27
  3. Software Driven Reset Routine
    Last Post: - 11th April 2005, 00:53
  4. reset and interrupt vectors
    By dtoohey in forum mel PIC BASIC Pro
    Last Post: - 28th February 2005, 22:02
  5. Replies: 5
    Last Post: - 1st December 2004, 12:49
