pwm receiver
Results 1 to 7 of 7
Thread: pwm receiver
    Aug 2007
    Default pwm receiver
    hello everybody
    please I want a project that receive different pwm signals that each one control one relay using pic 16f628 and picbasic
    thank you
    Typically, you don't receive PWM signals, unless it's a servo.
    Can you give more information about what you want to do.
    Aug 2007
    Thank you Darrel Taylor
    I mean I want to make a circuit with pic 16f628 with 10 outputs which receive signals.
    If it receive 10 khz for example the first output open , and if it receive 50 khz the second output open ,and if it receive 100 khz the third output open ,and so on...
    Post No problem ...
    Just see manual $ 5.9 ... Count function can "catch" a square 125 khz square wave ( 20 Mhz xtal ) ... and some Pics can reach 40Mhz !!! (250 Khz in ... )
    Aug 2007
    Sorry I don't understand
    Alain is refering to the COUNT command that is part of Picbasic Pro.
    In some manuals more information can be found in section 5.9.
    In other manuals it's 5.10
    Since you are trying to measure frequency, instead of Pulse Width Modulation, all you need to do is count the number of pulses received in a specified amount of time.
    The higher the COUNT, the higher the frequency.
    Aug 2007
    Default Thank You
    Thank You Thank You
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM: Vernacular/Function (Newbee)
    By TerryN in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 17:58
  4. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
