Is a timer delay accomplished with an interupt?
Results 1 to 3 of 3
    Jun 2007
    Default Is a timer delay accomplished with an interupt?
    I'm a hobbyist trying to teach myself PBP by experimenting. My current project is replacing the lights in my 1973 Honda motorcycle with LEDs. When the brake light is activated, I'd like for the LEDs to pulse several times, with progressively longer intervals (100ms, 200ms, 300ms, etc) and then stay on until the brake is released. Many modern bikes do this as a deceleration warning to help avoid getting rear-ended.
    In PBP, I basically run a continuous loop until a pin is high and then do a GOSUB to execute the flash loop, which takes about 2.5 seconds to complete. What I'd like to do is add some sort of timer to prevent the flash routine from executing more than once every 5-10 seconds. If I'm slowing down for a turn, I might depress and release the brake a few times. The flash loop should be executed only the first time I depressed the brake; subsequent activations should just keep the pin high until the brake is released. After x seconds, the next activation causes the flash sequence again.
    From my readings, it looks like I'll need to use an interrupt to time how longer it's been since the brake was last activated. But I can't wrap my head around how to use them. Could someone please provide me with an example? Thank you!
    Wink The fair ( and simple ) solution ...
    Hi ShortBus,
    I Hope your bike is not a CB 250/350 ... no emergency brake signal needed ... cause no break at all !!! LOL ...
    But ... I'd bet for a CB 750 ...
    Being serious ... no interrupt needed :
    a fair solution could be to use a 32.768 Khz Xtal for clock ... and let TMR 1 ( 16 Bits ) run quietly ...
    that permits to use 12F683 and 16F628 as "simple" Pics.
    How to ???
    By polling the TMR 1 Overflow bit !!! (TMR1IF)
    Let's have TMR 1 running freely : an overflow will occur after the delay you want "not to re-arm the flashing sequence" ... let it run ...
    Let's use the brakes :
    Overflow bit is set : engage the flashing sequence, and when releasing brakes... quit the flashing sequence and reset TMR 1 and it's Overflow bit ...
    re use the brakes :
    - before "Timeout" : overflow bit is clear ... continuous lighting !
    - after "Timeout" : overflow Bit is set ... engage the flashing sequence !!!
    32.768 Khz Xtal ??? just will need you to correct the programmed times by x 122 if using the Std "DEFINE Osc 4"
    ( Programmed PAUSE 10 will give 1220 ms instead of 10 ms ... so, if needed, use Pauseus :
    Pauseus 1000 will give 122 ms instead of 1 ms ... )
    This is just not to twist your brain on how to create " 1 - 10 seconds" delays ...
    Alain ... Genuine Kawasaki H1 rider ... ha,ha,ha !!!
    Sep 2007
    Hi ShortBus,
    How to ???
    re use the brakes :
    This is a very old thread, but I as a fellow rider I thought I should add
    something important in case others want to make their own flashing
    brake light.
    The word of the day is "FAILSAFE" ... as in "when it fails, the
    default condition is a safe condition".
    A PIC & associated parts is a complicated device. It can crap out for
    no obvious reason. The way the original poster was planning to use
    the PIC called for it to power his brake light, introducing a 'pulsing'
    effect before going solid on. This is a mistake and can cause a
    garbage truck to go up his behind.
    The FAILSAFE way ... or close as you can get ... is to make sure the
    power from the brake switch ALWAYS goes DIRECTLY to the bulb/LEDs.
    This calls for the introduction of a relay - mechanical or (better) solid-
    state - into the design. Wire the 'hot wire from the brake switch through
    the "NC" (normally closed) contacts of the relay and then straight to the
    light. This means the default mode is that the light will always come
    solid on when you press the pedal/brake-lever just like it was originally
    designed to do.
    The PICs job here isn't to power the light, but instead to power the RELAY.
    The simplest approach is to suck power from the brakelight wire and use
    that to power-up the PIC. Fewer running hours = less chance of failure.
    The PICs program commands a pin attached to the relay coil. You could
    use just a couple of "Pause()" statements between commands to toggle
    that pin on and off to get the timing just the way you want.
    The signal from the PIC energizes the relay, pulling the "NC" contacts open
    thus breaking the circuit. The brake light goes out for as long as the relay
    is energized.
    The most likely scenerio if the PIC fails is that it will source no current. In
    that case, using this design, the brakelight will come on solid and stay that
    way as long as you've got the brakes engaged - just like the factory intended.
    The PIC doesn't so much blink the lights as it "un-blinks" ... briefly interrupts
    the normal flow of power to the light.
    If you power it from the brake wire (the side BEFORE the relay) you don't
    have to poll anything or do interrupts, the PIC will use it's power-up time
    as a reference and count its 'unblink' sequence from that moment.
    For added safety against the possible electrochemical effects of wet wires
    on a solid-state relay, ground the "coil" lead through a 10K or 22K resistor
    to ensure it's not activated by tiny stray currents. Mechanical relays are
    not so sensitive, but the contacts can eventually burn out.
    An alternative to a relay is an old-fashion bipolar NPN transistor (these
    are tougher than CMOS varieties) - any of a dozen kinds will do, just
    don't hesitate to pick one with a higher current capacity - a TO-220a
    packaged kind will do nicely. Then tie the 'base' lead to the brake-wire
    side with a 1/2-watt resistor ... 1K ought to work, 5K is better for
    this app IF will work with your choosen transistor ... so that the
    transistor automatically conducts when you hit the brakes.
    The PICs job is to be also attached to the 'base' lead - but THIS
    time to "suck away" the power being provided through that 5K
    resistor. 12v / 1000 ohms = 0.012 amps ... which is within the
    amp range most PIC pins can sink safely. When in doubt, add a
    buffer amplifier between the PIC and the NPN 'relay' transistor.
    Just make sure the "broken" condition of the buffer amp is to
    draw NO power from the NPN transistors 'base' lead.
    Frankly, you're better off with a small automotive or "rugged
    service" grade of solid-state relay. It costs a bit more than
    the transistor, but it's got some worthwhile safety features
    hidden within.
    Anyway, I hope everyone gets my point ... as your life may depend
    on the brakelight working, do NOT trust a homebrew PIC to do the
    job. Make sure the light will ALWAYS come on, then use the PIC to
    force it to turn off for the "blink" effect.
    -Jimbo (motorcycle #15 and counting)
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  3. timer interupt help 16f73
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 08:41
  4. Memory Space of the PIC16F84...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 19:55
  5. Problem with saving to EEPROM...
    Last Post: - 1st July 2005, 00:10
