Volume Control On Piezo
Results 1 to 3 of 3
    Feb 2005
    Smile Volume Control On Piezo
    I am trying to control the volume of a piezo by PWM, but
    not a great deal of success.
    I have also tried HPWM, but the same.
    Peizo operating freq 4100 hz
    PIC 16F628A
    Int Osc, CMON = 7 Vol var word
    etc done
    For Vol=100 to 250 step 10
    PWM PortB.3,vol,10
    Pause 200
    next
    HPWM 1,vol,10
    Pause 200
    next
    Both cause a scratchy sound, with a little volume control.
    I am trying to eliminate a resistive pot, and use to PB, for up/down.
    kind regards
    Peter
    Pete
    Hi Peter,
    I am thinking Piezo element is a high impeadance device, you are probably feeding it through a small series capacitor, what would happen if you lower the impeadance with a resistor in parallel with the piezo element to help use up some of the power delivered through the capacitor? Then I believe the duty cycle change would have more effect.
    Jun 2005
    West Australia
    Default Try a parallel choke instead...
    You will have more efficiency and volume by using a small choke (coil) across the piezo to better the resonance. Some experimentation with size (micro Henry) is needed but any will show the difference from none...
    Bill
    edit... play safe and install a series resistor though, say 330 or 470 ohms.
  1. How do I give a radio control car autonomous control
    By Kenjones1935 in forum General
    Last Post: - 17th January 2010, 15:40
  2. pt2258+16f877 how can i use for 5.1 volume control ?
    By whyliving in forum mel PIC BASIC Pro
    Last Post: - 26th January 2008, 17:51
  3. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 08:18
  4. Volume Control IC's
    By HarryK in forum General
    Last Post: - 8th March 2005, 08:46
  5. Remote control
    By Radiance in forum General
    Last Post: - 6th August 2003, 15:13
