Xtal for 16f84a-16f628a
Results 1 to 9 of 9
    Jun 2006
    Default Xtal for 16f84a-16f628a
    I have wrote a programm for 16f84a and 16f628a with crystal 4MHZ.
    If i change the crystal to 20Mhz and define 4 to define 20 , will that works;
    Red face May be yes, May be no ...
    Hi, Savnik
    Depends on what your program is supposed to do and how it is written ... my Crystal ball is out for repairs !!!
    Timing instructions ( PULSIN, RCTIME,COUNT,FREQUOUT, etc ...) will especially be modified ... as stated in the PbP Manual ... if you've spread some assembler, or use interrupts, may be some registers preloadings ( TMRs i.e.) will have to be modified ...
    No more details available without knowing what you've written ...
    Jun 2006
    Hi, Savnik
    If i want to turn on and off one led;
    Quote Originally Posted by savnik View Post
    If you JUST want to turn the led ON or OFF ... no mod. involved.
    Note with the DEFINE OSC 20 ... PAUSE and PAUSEUS will still give the "written" time.
    Jun 2006
    I don't want to change the code.I ask because i have one pic16f84a-04 and one pic16f628a
    For 20Mhz, you'll also need to change the oscillator config to HS.
    Jun 2006
    I know , but the pic16f84a-04 and pic16f628a work with crystal 20 Mhz;
    Mar 2006
    Hyderabad (India)
    please go thro the datasheet Ds35007B in respect of PIC16F84A-4/20-- figures 9-1 and 9-2 and relevent comments. it is however possible as per the datasheet but voltage restrictions apply , i beleive.
    for PIC16F628A, it is possible to have any crystal.
    In both cases appropriate config commet to be moddedas you know already
    Sarma
    Jun 2006
    Quote Originally Posted by mvs_sarma View Post
    Thank you.
  1. Xtal speed vs PIC power
    Last Post: - 4th January 2010, 19:55
  2. Crystal oscillator problems on a 16f628a
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 16:33
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 10:21
  4. using internal xtal
    By jojokatada in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2005, 16:25
  5. HSEROUT and 16F628A
    By fredblah in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 00:07
