Dead PICs
Results 1 to 17 of 17
Thread: Dead PICs
    Default Dead PICs
    I have a circuit done that is giving me lots of dead PICs for some reason. The PICs program fine but when installed in the circuit they lose there functionality and I can no longer program them nor can I even read them. Even the target ID is set to 0000 as well as all the memory locations. I have not put code protect on either. Once this happens the chips become totally useless. Any one have any ideas? The PICs I'm using are the 16F628A and the 16F88. I thought there might be a problem with the F628A for I tried the F88 and the exact same problem.
    Few things that come to mind are:
    Have you measured the +5 volts relative to the ground ON the chip directly?
    Do you have any floating inputs or connected to other voltages relative to the ground of the PIC?
    Is the MCLR pin properly setup and connected?
    There are 4 floating inputs that I missed when the board was produced, porta.4, porta.5, porta.6 and porta.7. They should have been pulled up but I missed them as I was in a hurry to get the boards finished. Below is the code that I'm using in the device.
        low porta.2 : low porta.1 : low porta.3 : low porta.0
    @ __CONFIG _BOREN_ON & _CP_OFF & _DATA_CP_OFF & _PWRTE_ON & _LVP_OFF & _WDT_ON & _INTOSC_OSC_NOCLKOUT & _MCLRE_OFF
    '----------------------------  Port Assignments --------------------------------
    ' porta.0       Output 3 LED
    ' porta.1       Output 1 LED
    ' porta.2       Run LED
    ' porta.3       Output 2 LED
    ' porta.4       Unused
    ' porta.5       MCLR
    ' porta.6       Unused
    ' porta.7       Unused
    ' portb.0       Input 3
    ' portb.1       Input 2
    ' portb.2       Input 1
    ' portb.3       HPWM Output
    ' portb.4       Up Button
    ' portb.5       Down Button
    ' portb.6       Program Button
    ' portb.7       Debug Output
    '----------------------------  EEPROM Locations --------------------------------
    ' 0     Output 1 Setting
    ' 1     Output 2 Setting
    ' 2     Output 3 Setting
    '----------------------------  Debug Settings ----------------------------------
    '    DEFINE  DEBUG_REG       PORTB   ' Debug port
    '    DEFINE  DEBUG_BIT       7       ' Debug port bit
    '    DEFINE  DEBUG_BAUD      2400    ' Debug baud rate
    '    DEFINE  DEBUG_MODE      1       ' Debug mode 1 = inverted
    '    DEFINE  DEBUG_PACING    300     ' Delay 'in micro sec' between characters sent
        i       con     254             ' Control byte
        clr     con     1               ' Clear the display
        line1   con     128             ' Move cursor to home position on line 1
        line2   con     192             ' Move cursor to home position on line 2
    '------------------------------- Variables -------------------------------------
        StillPressed    var     bit
        x               var     byte
        Output1         var     word
        Output2         var     word
        Output3         var     word
        StartupDelay    var     byte
        TimeOut         var     byte
    '------------------------ Miscellaneous Variables ------------------------------
        Output3LED      var     porta.0
        Output1LED      var     porta.1
        RunLED          var     porta.2
        Output2LED      var     porta.3
        UpButton        var     portb.4
        DownButton      var     portb.5
        SetupButton     var     portb.6
        Input1          var     portb.0
        Input2          var     portb.2
        Input3          var     portb.1
    '---------------------------  Port Initialization ------------------------------
        TRISA = %00100000
        TRISB = %11110111
        CMCON = %00000111
        CCP1CON = %00001111
        OPTION_REG.7 = 0
    '----------------------------- Main Program Loop -------------------------------
        data 65,129,194
        include "Elapsed.pbp"
        gosub ResetTime                                                             ' Reset Time to  0d-00:00:00.00
        gosub StartTimer                                                            ' Start the Elapsed Timer
        clear
        StartupDelay = 34
        TimeOut = 20
    DelayedStartup:
        if portb.7 = 0 then main
        toggle RunLED
        pause 250
        if Seconds < StartupDelay then DelayedStartup
    '   debug i,clr
        if SetupButton = 0 and StillPressed = 0 then
            StillPressed = 1
            gosub ResetTime
            goto Setup
        StillPressed = 0
        high RunLED
        read 0,Output1 : read 1,Output2 : read 2,Output3
        if Input3 = 0 then
    '       debug i,line1,"OUTPUT 3 = ",dec3 Output3,"  "
            low Output1LED : low Output2LED : high Output3LED : hpwm 1,Output3,1000
        if Input2 = 0 then
    '       debug i,line1,"OUTPUT 2 = ",dec3 Output2,"  "
            low Output1LED : high Output2LED : low Output3LED : hpwm 1,Output2,1000
        if Input1 = 0 then
    '       debug i,line1,"OUTPUT 1 = ",dec3 Output1,"  "
            high Output1LED : low Output2LED : low Output3LED : hpwm 1,Output1,1000
    '   debug i,line1,"OUTPUT = OFF    "
        low Output1LED : low Output2LED : low Output3LED : hpwm 1,0,1000
    Setup:
        low RunLED
        low Output1LED
        low Output2LED
        low Output3LED
        if SetupButton = 0 and StillPressed = 1 then Setup
        StillPressed = 0
        pause 50
        read 0, Output1
    Output1Setup:
        high Output1LED
        hpwm 1,Output1,1000
        if SetupButton = 0 and StillPressed = 1 then Output1Setup
        StillPressed = 0
        pause 50
    StillPressed1:
        if SetupButton = 0 then
            gosub ResetTime
            StillPressed = 1
            low Output1LED
            pause 250
            if SetupButton = 0 then StillPressed1
            write 0,Output1
            read 1, Output2
            goto Output2Setup
        if UpButton = 0 then
            gosub ResetTime
            x = x + 1
            if Output1 + x > 254 then
                Output1 = 255
                goto Output1Setup
            Output1 = Output1 + x
            goto Output1Setup
        if downbutton = 0 then
            gosub ResetTime
            x = x + 1
            if Output1 < x then
                Output1 = 0
                goto Output1Setup
            Output1 = Output1 - x
            goto Output1Setup
        StillPressed = 0
        x = 0
        if Seconds => TimeOut then
            read 0, Output1
        goto Output1Setup
    Output2Setup:
        high Output2LED
        hpwm 1,Output2,1000
        if SetupButton = 0 and StillPressed = 1 then Output2Setup
        StillPressed = 0
        pause 50
    StillPressed2:
            gosub ResetTime
            StillPressed = 1
            low Output2LED
            pause 250
            if SetupButton = 0 then StillPressed2
            write 1,Output2
            read 2, Output3
            goto Output3Setup
            gosub ResetTime
            x = x + 1
            if Output2 + x > 254 then
                Output2 = 255
                goto Output2Setup
            Output2 = Output2 + x
            goto Output2Setup
            gosub ResetTime
            x = x + 1
            if Output2 < x then
                Output2 = 0
                goto Output2Setup
            Output2 = Output2 - x
            goto Output2Setup
        StillPressed = 0
        x = 0
            read 1, Output2
        goto Output2Setup
    Output3Setup:
        high Output3LED
        hpwm 1,Output3,1000
        if SetupButton = 0 and StillPressed = 1 then Output3Setup
        StillPressed = 0
        pause 50
    StillPressed3:
            gosub ResetTime
            StillPressed = 1
            low Output3LED
            pause 250
            if SetupButton = 0 then StillPressed3
            write 2,Output3
            gosub ResetTime
            x = x + 1
            if Output3 + x > 254 then
                Output3 = 255
                goto Output3Setup
            Output3 = Output3 + x
            goto Output3Setup
            gosub ResetTime
            x = x + 1
            if Output3 < x then
                Output3 = 0
                goto Output3Setup
            Output3 = Output3 - x
            goto Output3Setup
        StillPressed = 0
        x = 0
            read 2, Output3
        goto Output3Setup
    Hangover, Germany
    Red face
    I see no 100nF C near the PIC.
    What is about the 22uF-Cs near the optocouples ? What should they do ?
    Quote Originally Posted by BigWumpus View Post
    There are four 0.1uF capacitors in the circuit that are not shown on the schematic. One is located on the output from the 78L05, another is on the output from the 7812, another one is on the power pins right at the PIC and the last one is located right beside the OP-Amp.
    The 22uF are there to keep the PIC inputs from cycling on and off caused by the AC voltage used for the inputs.
    Mar 2004
    UK-Midlands
    Had a quick look at the schematic and can see nothing that I would expect to kill a PIC.
    But I have some ideas for you to consider?
    The 24vac supply for the power and the switches, are they independent or the same supply?
    If independent are the earths connected? Can you isolate the switch earths from the rest of the circuit?
    Having AC around with floating inputs definitely not recommended. Is there a good clearance between the 24vac and the PIC circuit? Can you tie the unused pins to ground with resistors?
    Are the PICs killed within seconds of powering up? Are they killed on the bench or after connecting to its intended 'world'?
    Hope this is of some help!
    Bob
    PS If the diagnostic input gets a static charge or voltage spike this would be relayed via the PICs internal port diodes to the 5v rail.
    Also note that 78L05 has the input/output pins in reverse order than that you would expect looking at the device facing you and the pins downside, e.g. Out-Gnd-In.
    Have you checked that you really have +5 at PIC's pins?
    The 78L05 is oriented in the boar correctly and there is only 5V powering the PIC. The thing that's getting me the most is that this is a intermittent problem and I'm running out of things to look at beside the floating inputs. Can these 4 pins just be pulled high or do then have to go to ground?
    Mar 2004
    UK-Midlands
    Interesting problem!!
    I would suspect a voltage surge on the 5v rail when powering-up. Have you tried increasing the capacitance on the 12v rail to deaden surges hitting the 5v regulator. I have seen some 7805 (not 78L05) regulators 'whistle' on their output giving peaks of 8 volts if the capacitance is too small.
    Is there any big inductive loads powered from the supply?
    The unused inputs can be tied to ground or 5v with resistors (1k).
    Last week 4 PICs went south after passing a functionality test on the bench
    Was this a test using the PCB but with nothing connected? Do the PIC's die with just power connected or on load?
    If every PIC dies on the bench in different (but identical) PCB's then I would look at the board layout carefully. If you can post a picture of track and component side I will look at it.
    Looking at the pin function I noticed that porta.5 is shared with MCLR and Vpp. Just wondering if since it's floating that it somehow goes into a programming mode or something.
    Quote Originally Posted by BobP View Post
    Bob
    Everything uses the same power transformer and a common ground. The PICs are killed instantly when power is applied to the board on the bench. The diagnostic input is only used to bypass an internal startup delay timer. There is no connection to this pin other than a header socket so this should not cause any problems. Last week 4 PICs went south after passing a functionality test on the bench. The only thing that I can think is it has something to do with the floating inputs.
  1. Communicating between two PICs over DC bus
    Last Post: - 7th May 2009, 12:57
  2. connect two pics
    By soki in forum mel PIC BASIC Pro
    Last Post: - 23rd September 2008, 06:29
  3. Retrieving infos from multiple PICs on a bus/chain
    Last Post: - 15th October 2007, 04:42
  4. Programming Pins of PICs?
    Last Post: - 15th August 2007, 18:59
  5. Self Destructing pics? Copy protection
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2004, 09:39
