Configuration of 16F737
Results 1 to 4 of 4
    Jun 2007
    Germany
    Default Configuration of 16F737
    Hi there,
    i need some informations about the configuration of a 16F737.
    All Pins should be set digital.
    Pin1 = MCLR or RE3
    Pin9 = OSC1 or RA7
    PIN10 = OSC2 or RA6
    How looks the settings for this part e.g. with MCLR, RA6 & RA7 connected to a crystal (ADCON1, CMCON,...)
    Is it always the same like in other picīs?
    ADCON1 = %111
    CMCON = %111
    The config header or modifying the 16F737.inc file is the same as others.
    With out looking at the data sheet myself...
    ADCON1=7
    CMCON=7
    xt_osc or XT_OSC
    mclr_off or MCLR_OFF to make RE3 an input. Will not output.
    What is not working?
    Jun 2007
    Germany
    That was just a question, before i start to build a schematic. If some options are unavailable, then i got problems with dimensioning my board.
    Well then the best thing to do would be to study the data sheet.
    Good luck.
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. Configuration error
    Last Post: - 20th September 2009, 01:10
  3. 16F726 configuration
    Last Post: - 8th February 2009, 18:53
  4. meProg configuration vs setting fuses in code
    By AndrewC in forum General
    Last Post: - 10th June 2008, 15:00
  5. 4-20mA to 0-5V configuration
    By leonel in forum General
    Last Post: - 31st August 2005, 13:33
