how to save value in pic16f84a
Results 1 to 9 of 9
    Apr 2007
    mackrackit..
    the sample code you wrote did not work, the stepper just moves to left for ever.
    i changed my last code ..
    i put a delay after read and write instructions, and i changed the place of write instruction.
    after these changes the stepper just do its job in the first stage ( when p = 13 and return back) ...then it start to go left and right randomly.
    after all this i read the eeprom postion of P, it gives me a big value than 13 !!.
    i think that there some mistakes in logical operators i used..but i dont know where ?
    this is my new code..
    any idea plz??
    ibra,
    The code I gave was trying to show where, when, and how to write to eeprom. It should not have changed the operation? At some point 13 should have shown up.
    I do not have a stepper on the bench at the moment so this is untested on my part.
    The idea is to have positive data written after every CW step (P=P+1)and negative data after every CCW step(P=P-P).
    IF PORTB.6 = 0 AND P<=13 THEN ;go RIGHT
     GOSUB RIGHT
     IF PORTB.7 = 0 AND P>=1 THEN ;go LEFT
     GOSUB LEFT
    This looks like the random problem. P<=13 -- P>=1 Stuck between these values. It would have to be greater than 13 or less than 1 to stop.
    Or, make PORTB 6 or 7 high in hardware and tell the PIC what to do when they are high. (STOP)
    I will try to test with a stepper in a day or so.
  1. Using serial eeprom to save data ?
    By iugmoh in forum General
    Last Post: - 8th February 2008, 09:36
  2. Serial Communication Using PIC16F84A
    By fazan83 in forum GSM
    Last Post: - 22nd January 2007, 03:56
  3. save data in pic
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 17th May 2006, 22:17
  4. How to connect PIC16F84A to mobile phone
    By PoTeToJB in forum Schematics
    Last Post: - 8th March 2006, 16:32
  5. Replies: 3
    Last Post: - 16th April 2005, 13:42
