how to save value in pic16f84a
Results 1 to 9 of 9
    janH,
    The link I gave in post #3 http://www.picbasic.co.uk/forum/showthread.php?t=5649 is a discussion on how to force the PIC to save on a power down.
    ibra,
    I gave you some sample code for your stepper motors.("problem with stepper ") Did it work? If not, what happened?
    Apr 2007
    mackrackit..
    the sample code you wrote did not work, the stepper just moves to left for ever.
    i changed my last code ..
    i put a delay after read and write instructions, and i changed the place of write instruction.
    after these changes the stepper just do its job in the first stage ( when p = 13 and return back) ...then it start to go left and right randomly.
    after all this i read the eeprom postion of P, it gives me a big value than 13 !!.
    i think that there some mistakes in logical operators i used..but i dont know where ?
    this is my new code..
    any idea plz??
    ibra,
    The code I gave was trying to show where, when, and how to write to eeprom. It should not have changed the operation? At some point 13 should have shown up.
    I do not have a stepper on the bench at the moment so this is untested on my part.
    The idea is to have positive data written after every CW step (P=P+1)and negative data after every CCW step(P=P-P).
    IF PORTB.6 = 0 AND P<=13 THEN ;go RIGHT
     GOSUB RIGHT
     IF PORTB.7 = 0 AND P>=1 THEN ;go LEFT
     GOSUB LEFT
    This looks like the random problem. P<=13 -- P>=1 Stuck between these values. It would have to be greater than 13 or less than 1 to stop.
    Or, make PORTB 6 or 7 high in hardware and tell the PIC what to do when they are high. (STOP)
    I will try to test with a stepper in a day or so.
  1. Using serial eeprom to save data ?
    By iugmoh in forum General
    Last Post: - 8th February 2008, 09:36
  2. Serial Communication Using PIC16F84A
    By fazan83 in forum GSM
    Last Post: - 22nd January 2007, 03:56
  3. save data in pic
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 17th May 2006, 22:17
  4. How to connect PIC16F84A to mobile phone
    By PoTeToJB in forum Schematics
    Last Post: - 8th March 2006, 16:32
  5. Replies: 3
    Last Post: - 16th April 2005, 13:42
