Need Help - Line Tracer Robot
Results 1 to 5 of 5
    Aug 2007
    Default Need Help - Line Tracer Robot
    hi all,
    need help here...im new in pic...
    i would like to make a line tracer robot....the function would be like this....
    there is a grid line field, i mean a lot of horizontal and vertical lines make a lot of square.
    so the robot will first follow a straight vertical line, and after it pass through 7 horizontal lines, it will turn 90 degrees, and then it will go straight again and after it pass 4 horizontal lines, it will stop for few seconds and it will do some other jobs using different motor.
    so basically the robot will move in 'L' shape.
    im using power window motor, and pic16f877 as my controller....
    thank you
    So, where are up to this moment? Schematics, snippets, problems?
    Wink
    Will this help you ??? : http://www.parallax.com/dl/docs/book...boticsV2_2.pdf
    EVERYTHING Explained in details ... and it is PbP Compatible !!!
    Aug 2007
    i got problem with the programming
    Quote Originally Posted by pidot View Post
    SO.....wheres the code?
  1. Replies: 0
    Last Post: - 2nd February 2009, 23:23
  2. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 05:02
  4. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 12:22
  5. Line tracer robot
    Last Post: - 30th January 2005, 15:36
