With transitors, the current you get out is dependant on the current from the base to emitter. If the voltage on the emitter changes, then the base to emitter current will be reduced. So if the load is between the emitter and power, ... as the transistor starts to conduct, the emitter voltage changes and counteracts the base current that's trying to turn it on. While it seems to kinda sorta work a little bit, you always end up with a lower current output.Is there a difference in connecting the load between emitter and ground, or between collector and vdd (besides resistance increasing base to ground when the load is on the emitter side)?
So basically, you want the emitter to be at a constant voltage, either GND or V+.
But the difference is ... if you want to "source" current to the load from V+ (like in the first schem.) you would use a PNP transistor. Then output HIGH from the PIC is OFF, and LOW is ON.
And as I read this back, it doesn't even make sense to me. (I'm a software guy).
Alain!!! Help!!!! Anybody!!!
