Problem with manchester code for RF
Results 1 to 12 of 12
    dhouston, How can you say: Manchester encoding is not immune from noise but does have built-in error detection. What is the "built-in error detection"? This is news to me as I write software for Tire Pressure Monitoring equipment which uses Manchester coding. Please explain.....
    Dec 2005
    If you don't see a change of state at the middle of a bit period, you've detected an error which is usually the result of noise if you are using it over a wireless link or a collision if you're using it over a wired link (e.g. 802.3, X-10). See the last paragraph at http://www.wildpackets.com/support/c...ignal_encoding.
    dhouston, I call that type if "error detection" signal integrity, not error detection. You could have a noise source producing edge changes at the same rate as the baud rate you are trying to detect. Where is the error detection then?
    Dec 2005
    Call it what you like. I'll call it what it is.
    Dec 2005
    And where is the error if no low state gets changed to a high state?
    dhouston, Try deciphering 1 individual transmission of 128 data bits (256 states) with 4 or more transmitters being keyed at the same time.... The data states at the receiver might look good but what about the actual data..... Like I said... Signal integrity
  1. My first DT_INT code has a problem.....
    By E Kizer in forum mel PIC BASIC Pro
    Last Post: - 13th April 2009, 14:37
  2. Weird code problem
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 16th March 2009, 12:16
  3. Making Program Code Space your playground...
  4. Help with serin, serout, Manchester encoding
    Last Post: - 5th April 2007, 14:31
  5. Code problem
    Last Post: - 20th May 2006, 05:43
