USB Duplicator Help
Results 1 to 4 of 4
    Oct 2003
    Australia
    This project sounds interesting and ambitious...
    I suspect your going to have to tackle this one in steps.
    What stage are you up to so far?
    Squib
    Jul 2007
    Default Update
    Well I've moved backward and forward. It turns out the USB IC I was going to use only supports USB 1.1, way too slow. So here are the steps I have:
    1. Via Mini-ITX computer (creates master fileset, acts as USB host controller, control station with LCD monitor)
    2. 3 USB hubs to daisy chain out to the 10 external ports from the host
    3. 10 microcontrollers, each port is pulling data to their respective USB flash drive in parallel
    Steps 1 and 2 are the most straight forward, my problem is still with step 3. I can't find a USB 2.0 IC for pic controllers. And can't figure out how each of these ports can use USB to pull data from a USB host?
    The whole thing reminds me of a hub repeater so I may look to use ethernet if nobody can help me connect these USB pic ports to the host mini pc.
    Again, any help is appreciated!
    Oct 2003
    Australia
    Ted,
    Why don't you just write a VB program to do the same thing, since your using a PC plugged into hubs and USB flash drives?
    It might be worth browsing some VB forums, you never know this may have already been done.
    I don't think PIC is the way to go.
    Squib
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. USB Bootloader.
    By HenrikOlsson in forum USB
    Last Post: - 2nd May 2013, 02:46
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  4. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 00:04
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
