array in constant?
Results 1 to 14 of 14
    Quote Originally Posted by SpiritHunter View Post
    how many constant can i write in a single bracket? and... is there a problem if i write like this?
    LOOKUP a,[1,2,3,4,5,6,7
    ,8,9,10],b
    Hi, SH
    Will 255 for a 16F series and 256 for a 18F series be enough ??? ( LOL !!!)
    Note this type of array takes a lot of room ( like with assembler ... 1 prog line per value + 1 ) and you might think at it when choosing your PIC ...
    PbP doesn't deal so well with room for this function ... and lots of room is lost with big lookup tables !!!
    Aug 2007
    Hi, SH
    ? 255 only? i am thinking of at less 500... as i need to bit map all the char in ascii which is at less need 101x5
    ya.. i know it takes alot of memory. and i have chosen 16F877A to do the job. i hope 8k is enough for the constants, I2C and a serial communication... if not enough, then i am in big troble.. haha...
    so... 16F877A can only allocate 255 in 1 lookup table? if so, den i need to separate the bit map codings.
    Wink
    Those are PbP limits !!! ... for LOOKUP ...
    you can also use an external pre-programmed EEPROM or use some READCODE ( see manual for the limits )... if your code space allows it ....
    note ... DATAs for READCODE can be loaded as an "include" file ... generated by your computer ! ( with "word", or much better "Excel" ...)
    Aug 2007
    thanks Acetronics, i can deal with the more then 255 problem.
    now another problem is that
    how can i write
    lookup a,[1,2,3,4,5,6,...........,255],b
    in multiple line? and adding comment in the end of each line?
    eg:
    lookup a,[1,2,3,4,5,6,7,8,9,10, ; line 1
    11,12,13,14,15, ; line 2
    .................... ],b
    lookup a,[1,2,3,4,5,6,_       'never tried comments on each line
              7,8,9,10,....,255],b ' but the normal way should work
    Aug 2007
    just add _ behind each line. got it... thanks
    Aug 2007
    thanks guys, not that the compiling part is finish, it's time to put it in the 16f877a and test it.
    the coding alone is around 6kb already. haha...
    Last Post: - 14th June 2016, 07:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 04:46
  3. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  4. RS232 receive an array (packet)
    Last Post: - 12th February 2008, 05:02
  5. Reading Array values into variables
    Last Post: - 21st March 2005, 10:30
