Just making a guess. You are setting the fuses in your code.
Have you read this? http://www.picbasic.co.uk/forum/showthread.php?t=543
Read the whole thing.
If this is not the problem, post the code.
Picman,
Most PIC chips already have a register called EEDATA.
If you are trying to create a variable or constant with the same name, you will get an error.
DT,
I don't know if my last reply got through, so I will list the code below that the assemblier is looking at.
Note: The last two lines are the problem, I think?? This code was included in the C:/pbp folder.....
Any ideas? Should I just remove the last two lines???
Picman 35
;* 16F917.INC *
;* By : Leonard Zerman, Jeff Schmoyer *
;* Notice : Copyright (c) 2005 microEngineering Labs, Inc. *
;* All Rights Reserved *
;* Date : 02/28/05 *
;* Version : 2.46a *
;* Notes : *
NOLIST
ifdef PM_USED
LIST
include 'M16F91x.INC' ; PM header
device pic16F917, xt_osc, wdt_on, protect_off
XALL
NOLIST
LIST
LIST p = 16F917, r = dec, w = -302
INCLUDE "P16F917.INC" ; MPASM Header
__config _XT_OSC & _WDT_ON & _CP_OFF
NOLIST
LIST
#define EEDATA EEDATL
#define EEADR EEADRL
No, those lines are there for a reason, and should stay there.
Can you post your code.
Has to be something else wrong.
DT,
I don't think it is the code. As stated, I can put one line and still give me the error.
This all started when I loaded the new MPLAB IDE v7.60. Could this cause the problem?? Or, maybe my settings???
Here is an example of a code that fails (it gives me the two errors)....
'* Name : UNTITLED.BAS *
'* Notice : Copyright (c) 2007 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 8/1/2007 *
'* Version : 1.0 *
'* Notes : *
OK my fault, wasn't thinking of (the latest) MPASM.
I just upgraded MPLAB and found that Microchip has changed a couple things.
They've added aliases that are the same as the defines in PBP's inc file.
The changes can be found in the P16F917.INC file in the MPASM folder.
So, you were right!
Just comment out those 2 lines and it should be fine.
Sorry,
DT,
Thanks! I appreciate your response.
I'll keep you updated on my progress (with the project).
Best Regards,
Picman 35
