Forget the opamp. The thread was talking about using a simple voltage divider to scale the signal voltage down to PIC level. If you have 6 volts use a 1 to 1 voltage divider to make 3 volts. Set the ADC reference voltage to see full scale (apply 6 v to divider ADC out put 255) and you should be good to go.
