Measuring time
Results 1 to 4 of 4
Thread: Measuring time
    Jul 2007
    Brazil
    Default Measuring time
    Hi, itīs my first topic. This forum solved many questions to me, just reading it ! Thanks a lot.
    Iīve got a problem...
    I want to measure the time between the second and the third press of a button. The first press is like a "preparing" to the measuring that ocurrs in then 2. and the 3. press.
    My basic code returns non-precise measured times, and I donīt know why.
    INPUT PORTB.0 ' input button
    OUTPUT PORTB.7 ' blinking-time led
    LED VAR PORTB.7 ' blinking-time led
    FLAGS = 0
    TEMPO VAR WORD ' time variable
    TEMPO = 500 ' value to start tempo
    A VAR WORD' variable that contains time measured
    INICIO: ' looks if the button was pressed or show the value of tempo
    ENABLE INTERRUPT : INTCON = %10010000
    ON INTERRUPT GOTO PAROU
    LCDOUT $FE,1,"TEMPO = ",#TEMPO
    LOOP1: ' blink the led
    TOGGLE LED
    PAUSE TEMPO/2
    TOGGLE LED
    PAUSE TEMPO/2
    GOTO LOOP1
    PAROU: ' prepare to measure the time
    DISABLE INTERRUPT : INTCON = $80
    LCDOUT $FE,1,"PREPARE"
    BOTAO VAR PORTB.0 ' transform the interrupt to button measure
    A=0
    PAUSE 200 ' cheap debouncing
    LOOPBOBO: ' debouncing for the first press to measure
    if botao=1 then LOO1
    GOTO LOOPBOBO
    LOO1: ' measure the time
    PAUSE 100 ' debouncing time (minimum measured)
    LOO:
    if botao=1 then fecha2
    pause 1
    pause 1
    pause 1
    pause 1
    pause 1
    pause 1
    pause 1
    pause 1
    pause 1
    pause 1
    A=A+1 ' increment time counter
    GOTO LOO
    fecha2:
    TEMPO = A*10 + 100 ' adjusts the time variable
    LCDOUT $FE,1,"OK"
    PAUSE 1000
    goto INICIO
    Thanks if someone could help me.
    Augusto Pedrone.
    São Paulo - Brazil.
    Bombay, India
    <B>From the manual</b>
    PBP will not enter the BASIC interrupt handler until it has finished
    executing the current statement. If the statement is a PAUSE or SERIN,
    it could be quite a while before the interrupt is acknowledged. The
    program must be designed with this latency in mind. If it is
    unacceptable and the interrupts must be handled more quickly, an
    assembly language interrupt routine must be used.
    This is just one of the reasons why.
    You may want to take a look at this http://www.picbasic.co.uk/forum/showthread.php?t=3251
    I hear it is pretty good
    I found this site to be easier on the eyes...
    http://darreltaylor.com/DT_INTS-14/blinky.html
  1. need help for measuring two freq at same time
    By vu2iia in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2009, 04:48
  2. I don't understand this code!
    By Russ Kincaid in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 02:55
  3. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:55
  4. Time Measuring
    By peterson in forum mel PIC BASIC Pro
    Last Post: - 20th May 2006, 17:22
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 14:24
