LCD displaying problem..
Results 1 to 17 of 17
    Actually GrandPa your option won't work.
    Your logic is good, but you haven't completely thought it thru... (you still had $8D instead of $80 by the way - but forgetting that)...
    Suppose you're dropping in speed... 101, 100, 99 <<< and there's the problem...
    The last display was 100, you now shift over by one character postition and you display '99' over the top of the '00' part of 100. You haven't erased the '1' so your display goes...
    101, 100, 199, 198 etc etc...
    Keith hit it in one... but if you don't want a waving km/h display those first... and then just concentrate on the numbers. You can have leading or trailing blanks then (depending if you want left or right numeric justification).
    OK... Keith got there first... *smiles*
    Feb 2003
    That makes a change
    Normally I type a reply and post it to find that 3 or 4 other people have replied whilst I was typing.
    The problem was even worse on one forum when I didnt have access during the day. By the time I got to read the messages there was no point in replying until I had read all messages as invariably someone eles had already said what I was going to!
    Quote Originally Posted by grandpa
    $8D ??? I think you meant $80 (beginning of first line)
    $80 would indeed be the start of the first line but $8D would be character position 14 on the first line. With a 20 character display this would give space for xxxkm/h to be right justified on the display which is what I suspect sirvo is trying to achieve.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Apr 2007
    Default Wow
    Man I learn alot reading this forum!
    Where is the above mentioned "$8D" command documented? I had no idea you could do that? I knew you could shift right or left but did not know you could "jump" to a position...
    Thanks to everyone for the education!
    Bill12780
    Feb 2003
    Quote Originally Posted by bill12780 View Post
    Bill12780
    Hi Bill,
    It isnt specifically mentioned in the PBP manual as it depends on the LCD driver chip in your display but for any HD44780 or compatable controller it will work.
    Download the datasheet for an HD44780 and look for the section on setting the registers.
    DDRAM is the command to look at.
    With bit 7 set you are setting where the data sent to the display is written.
    %1xxxxxxx
    $80 which is %10000000 is the first display position on Line1
    $C0 which is %11000000 is the first position on line 2
    increasign either of those values will move you along the line so that you can write at any position. This means you dont have to rewrite the entire display if all that is changing is a single character.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Bill12780
    Although Keith answered your question quite well, this information is documented on page 94 of the PicBasic Pro manual under the LCDOUT command section (pg 94 of the online version here http://www.melabs.com/downloads/pbpm304.pdf )
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Feb 2003
    Quote Originally Posted by paul borgmeier View Post
    Oops
    Cant find my printed manual at the moment to check if it is in there but on my Intranet I have the HTML version of the manual which I use as my reference.
    It must be a much older version as it doesnt have the sentance about
    LCDOUT $FE, $80+4.
    It just says "See the data sheet for the particular LCD device for the character memory locations and additional commands"
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Jul 2007
    Wink Fixed
    This will cover everything
    LCDOUT $FE,1, $80 + X, "your text here"
    OR
    LCDOUT $FE,1, $80 + X, #VAR here
    Where X is the number of needed space.
    Can also be broken in 2 instructions: LCDOUT $FE,1 : LCDOUT $FE, $80 + X, ...
    Note: I strongly recommend against using spaces, mainly because it eats up more program memory, hard to see on source code too:
    ex 1 : lcdout $FE,$80,"               99"  ---> 294 bytes used
    ex 2 : lcdout $FE,$80+15,"99"            ---> 200 bytes used
    Can make a big difference if used extensively!
    Hope It helps you sirvo and bill12780
    Apr 2007
    Default another revelation!
    Feels like I am at the Church of the Blessed PIC!
    Ok so here is a prime example of why you should read the entire section of the commmand.
    I glazed over it to get to the defines section so I could change the default port from A to D. I totally skipped the section on memory mapping.
    If I had read it, it would not have been such a revelation that the "commands" has they are refered to (in the manual) are actually "pointers" (for lack of a better term) to memory location within the LCD. I thought it was all PBP thing. Not LCD specific. Now I now...hahaha
    I am going to go over the Datasheet for the HD44780 when I get a sec. Cause I bet I can finally figure out how they do scrolling (horizontal and vertical). But for now still working on my Keypad project...
    Thanks you two! Time here is never wasted in my opinion. I learn something new each and everytime I come in here.
    Oh and by the way...I have just (like a month ago) ordered the upgrade from MElabs to 2.47. My orginal (your not gonna belive this) came on a FLOPPY! So I ordered the printed manual as well. My manual is the same as the online version. I am a bit old school (Still have my old TI Logic Databooks!) I like having the printed book. You can order just the manual from MELabs for like 10-15 bucks...
    Thanks again everyone!
    Bill12780
    Jul 2007
    Thumbs up Goto next level when ready
    Bill
    Ask (search) about BIG number whenever you feel ready. Someone made a really nice routine to display 4*4 number on LCD.
    J-P
    Jan 2007
    Brazil
    Quote Originally Posted by keithdoxey View Post
    That makes a change
    EXACTLY! I'm using a 4x20 display and the speed is going to be right justified!
    Thanks All for helping!
    Sylvio,
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 09:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  3. LCD problem
    By Andre_Pretorius in forum General
    Last Post: - 27th January 2009, 16:47
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. Need help with LCD number display.
