LCD displaying problem..
Results 1 to 17 of 17
    Jan 2007
    Brazil
    Default LCD displaying problem..
    Hello all!
    I'm trying to display this:
    speed   VAR   WORD
    LCDOUT $FE,$8D, DEC speed, "km/h"
    LCD results:
    Let's say speed is increasing and then decresing:
      98km/h
      99km/h
    100km/h
    101km/h
    100km/h
    99km/hh  ----> THE PROBLEM
    What is the 'secret' to solve this little problem?
    Thanks..
    Sylvio
    Try clearing the screen.
    speed   VAR   WORD
    LCDOUT $FE,1             'CLEARS THE SCREEN
    OR
    LCDOUT $FE,1,$8D, DEC speed, "km/h"
    Sep 2005
    Campbell, CA
    There are several ways, but the easiest is to add some blank spaces after "km/h" so your code instead looks like
    LCDOUT $FE,$8D, DEC speed, "km/h "
    Charles Linquist
    Feb 2003
    Quote Originally Posted by Charles Linquis View Post
    But that would result in the display moving about.
    Better to conditionally add space BEFORE the value to be display eg
    If speed < 10 then LCDOUT " " ' 1 space
    If speed < 100 then LCDOUT " " ' 1 space
    LCDUT DEC speed,"km/h"
    IF the speed is 100 or greater then no spaces are prefixed
    If the speed is 10-99 then one space will be prefixed
    If the speed is below 10 then both conditions will be met and two spaces prefixed resulting the display remaining in a static position on the screen
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Jul 2007
    Default My 2 cents
    First of all, I wonder about this line: LCDOUT $FE,$8D, DEC speed, "km/h "
    --- > $8D ??? I think you meant $80 (beginning of first line)
    Then, if it's the case you can use:
    If speed < 100 then X= 1
    If speed < 10 then X = 2
    LCDOUT $FE,$8D + X, DEC speed, "km/h"
    Cleaver!
    Feb 2003
    Quote Originally Posted by GrandPa View Post
    Cleaver!
    Whilst that would keep the "km/h" in the same position on the screen it WONT clear text that is previously written which is why you need to print spaces.
    With the above code you would get the following
    9 would give "9km/h"
    49 would give "49km/h"
    103 would give "103km/h"
    but when the speed drops you would get the following problem due to not clearing the leading digits
    87 would give "187km/h" (the "1" not being cleared)
    5 would give "185km/h" (both the "1" and the "8" not being cleared)
    Last edited by keithdoxey; - 29th July 2007 at 12:29. Reason: keyboard is getting knackered and some letters were missing!!!!
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Actually GrandPa your option won't work.
    Your logic is good, but you haven't completely thought it thru... (you still had $8D instead of $80 by the way - but forgetting that)...
    Suppose you're dropping in speed... 101, 100, 99 <<< and there's the problem...
    The last display was 100, you now shift over by one character postition and you display '99' over the top of the '00' part of 100. You haven't erased the '1' so your display goes...
    101, 100, 199, 198 etc etc...
    Keith hit it in one... but if you don't want a waving km/h display those first... and then just concentrate on the numbers. You can have leading or trailing blanks then (depending if you want left or right numeric justification).
    OK... Keith got there first... *smiles*
    Feb 2003
    That makes a change
    Normally I type a reply and post it to find that 3 or 4 other people have replied whilst I was typing.
    The problem was even worse on one forum when I didnt have access during the day. By the time I got to read the messages there was no point in replying until I had read all messages as invariably someone eles had already said what I was going to!
    Quote Originally Posted by grandpa
    $80 would indeed be the start of the first line but $8D would be character position 14 on the first line. With a 20 character display this would give space for xxxkm/h to be right justified on the display which is what I suspect sirvo is trying to achieve.
    Keith
    www.diyha.co.uk
    www.kat5.tv
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 09:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  3. LCD problem
    By Andre_Pretorius in forum General
    Last Post: - 27th January 2009, 16:47
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. Need help with LCD number display.
