using TMR0 as a counter..
Results 1 to 2 of 2
    Jan 2007
    Brazil
    Default using TMR0 as a counter..
    Hi! I have two question, can you help me?
    1) I'm using TMR1 as a timer and it ticks every 100ms. Now, I would like to measure an external clock (RPM) (0 - 1000Hz) and display it every 500ms on a LCD display. The extenal source is connected to RA4 and think it is possible to use TMR0 as a counter. The problem is that TMR0 is a 8-bit timer and it counts till 256 until overflow. So, my question is: If I set TMR0 prescaler to 1:4, would it be possible to count 256*4 = 1024 until overflow? I mean, will TMR0 count every 4 external ticks?
    Here is Bruce's TMR0 counter prescaled 1:1 from the forum. It uses interrupt but as my TMR1 ticks every 100ms, i think it's not necessary to interrupt TMR0.
    TRISA = %00010000    ' Set PORTA.4 (TOCKI) to input for timer0
       OPTION_REG = %00111000
       'Transition on TOCKI (RA4),
       'Increment on falling edge
       'Prescalar assigned to WDT for a 1:1 TMR0 ratio.
       INTCON.2 = 0 ' Clear Timer0 int flag
       INTCON.5 = 1 ' Enable Timer0 int
       TMR0 = 0   ' Set TMR0 to 0.
       ON INTERRUPT GOTO LapCount
       ' Do something here
       goto Main
       disable
    LapCount:
       TMR0 = 0      ' Indicate we're in interrupt handler
       INTCON.2 = 0    ' Clear TMR0 Interrupt Flag (Bit 2)
       Resume
       Enable
    2) If a set TMR2 prescaler to 1:256 and set TMR2 = 0, it will interrupt every ~65,5ms (4MHz crystal). I a set the postscaler to 1:16, will it interrupt every 16*65,5ms = 1,048s?
    Thanks in advance.
    Sylvio
    I am new here and do not have any experience with timers but I will try to help nonetheless, because I too am trying to learn about this...
    regarding 2) YES
    regarding 1) I think you are right about the timer0 counting every 4 ticks for prescaler 1:4 but only it will be counting till 256...what I mean is that timer0 is 8 bit.
    if you are measuring rpm at maximum of 1000HZ then Timer 1 should overflow the earliest after approximatly 1.024 second using prescaler 1:4. So you don't have to worry about an overflow before 500ms. On every 5th timer1interrupt (after 500ms) you could save the count in Timer0 to a word variable (and then reset it). This variable you need to multiply by 8 for the display in Hz(. (Times four because you are only counting every 4th clock....Times 2 because you've only been counting for 500ms. I believe multiplying by 8 is the same as left shifting by 3 (<< 3). This is why I would use a word variable to beginn with.
    Alternatively you could probably use prescaler 1:1 and Timer0 interrupts, to add the actual counted ticks to a (word sized) variable. You could start timer 1 and timer 0 at the same time... on each timer0 interrupts (about every 1/4 of a second) add 256 to the counting word variable. Then on the 5th timer 1 interrupt (using software counter), stop timer0 retrieve its value and add it to the counting word variable. The number in the counting word variable is multiplied by 2 (=<< 1) to get the count per second.
    I really suggest you have a look at Darrell Taylors instant interrupts pages
    http://darreltaylor.com/DT_INTS-14/intro.html
    or
    http://darreltaylor.com/DT_INTS-18/home.html
    He has made it easy for anyone to use multiple interrupt sources with pic basic pro and ASM interrupt handlers
    good luck!
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. TMR0 as counter
    Last Post: - 31st March 2009, 19:34
  3. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
  4. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 05:02
  5. Microcontroller with 2 way paging application problem
