PIC relays control
Results 1 to 21 of 21
Threaded View
  1. #8
    Apr 2006
    New Hampshire USA
    Post
    Hi Dom,
    Quote Originally Posted by flipper_md View Post
    I would really like a relay that behave like that!
    If it exist and the PIC can run it, that's what I want !!
    But the spec sheets aren't very descriptive in that manner...(attached Panason TN spec)
    double coils latching relays ask for 40mAh, and need 2 pins...
    About FET and other electronics switcher, i'm trying to avoid tehm because they draw some power just for operating.
    About Diodes, let's say I want to protect the PIC from the relay, I would use a 5V Zener?, or I need to add a safety margin? 4.5V?
    Lots of Amps in the coil effect of a relay?
    Thanks for all added info, i'm slowly but surely getting somewhere! 8)
    from the data sheet:
    Panasonic TN Relays
    1 Coil latching
    TN2-L-5 V
    5V 20mA 250-Ohm coil
    The TN2-L-5 V should work directly from standard (25mA) PIC I/O pins.
    I gave incorrect / incomplete information about latching relays in a previous post.
    A single coil latching relay changes state when the polarity on the coil is reversed.
    +++++ Info +++++
    Single coil latching relay
    DC Power to coil transfers contacts.
    Contacts maintain after coil power is removed.
    To transfer contacts to original position, DC Power to the coil is reversed.
    Coil suppression circuit:
    Circuit to reduce the inductive switch off voltage peak of the relay coil (EMC protection)
    The latching relay protection diode would have to allow either polarity.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1889&stc=1&d=118567495 4" />
    Then your PIC would Make I/O A high and I/O B low or I/O B high and I/O A low, to latch or unlatch the relay.
    We should mention that using the transistor in place of the relay does not use very much battery power.
    But, the PIC has to remain in control of the pin driving the transistor.
    I would consider using a logic level CMOS power transistor.
    -Adam-
  1. SMS control for Relays
    By charudatt in forum Code Examples
    Last Post: - 2nd May 2009, 01:08
  2. Replies: 5
    Last Post: - 12th September 2007, 16:59
  3. Motor Control PLC with a PIC
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2006, 08:59
  4. Pic Control With Software
    By Agent36 in forum General
    Last Post: - 18th October 2006, 19:18
  5. Need help on pic to pic flow control (simple problem I think)
    By khufumen in forum mel PIC BASIC Pro
    Last Post: - 11th January 2006, 01:34
