16F88 RA6 and RA7 troubles
Results 1 to 9 of 9
    May 2007
    Exclamation 16F88 RA6 and RA7 troubles
    I have been working with the 16F88 for sometime now, and despite that fact have yet to be able to configure and use the osc1 and osc2 pins as i/o porta.6 and porta.7.
    I know that this is an accessable feature of the 16f88 by configuring the FOSC2:FOSC0 bits to 7 (%110). So far I have not been able to figure it out even after over half a year, and I have searched everywhere online to no avail.
    Please if anyone has any information that could help me, and the many others I have found that don't have the answer either. I know the feature may be special to the 16f88 but we should still be able to access it.
    Many thanks to anyone who can give any input.
    Quote Originally Posted by gandora View Post
    %110 = 6
    %111 = 7
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    A quick look would suggest you could add
    ANSEL = 0
    to the code in post #4 here and be up and running. (You would still need to set TRISA accordingly for those pins)
    http://www.picbasic.co.uk/forum/show...ighlight=16f88
    UPDATE: In fact, the ANSEL=0 would not be needed because RA6 and RA7 are never analog - should work as posted in #4
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Melanie gets her whip out and locks Paul and Joe in a room for 'retraining'.
    RA6/OSC1 and RA7/OSC2 only comes alive when you use the 16F88 in it's Internal Oscillator mode... and that is a feature of the CONFIGURATION BITS of the PIC...
    So (assuming you're using the default MeLabs PM Assembler)...
    1. At the top of your program, along with your PIC device statements you need...
    @ DEVICE INTRC_OSC_NOCLKOUT
    or
    @ DEVICE pic16F88, INTRC_OSC_NOCLKOUT
    I refer you to...
    (a) the PICs Datasheet Section 15 Special Features of the CPU, Register Table 15-1 CONFIG1 Configuration Word.
    Also (b) http://www.picbasic.co.uk/forum/showthread.php?t=543
    Only then you will be able to use RA6 and RA7.
    2. However the game hasn't finished...
    This PIC has multiple Oscillator selection (see datasheet Section 4 Oscillator Configuration)... one of the very first lines of your program must set the OSCCON Register (see Datasheet Register Table 4-2 OSCCON) for the speed you want this PIC to run... (because the Power-On default is 31.25kHz) example...
    OSCCON=%01100000 ' Set PIC to 4MHz
    There's other things you can do too, but I won't go into that at this time...
    It's all in the Datasheet... crate of beer helps...
    Oooh... and make sure your PBP is up to date... something in the back of my mind is nagging me about early versions having a problem with the 16F88... go to the MeLabs website and check in the Versions list when the fix occurred...
    Default Whips and Beer !
    Woooo Hoooo, Promises, promises, promises ! Now I can't remember what PIC means . . .
    May 2006
    MI
    Ohhh, lock me and whip me too please.
    On a more serious note, I recall reading somewhere
    (with certain programmers) there was a problem with
    erasing the F88 with internal osc configured. Keep this
    in mind if your have trouble reprogramming. Hopefully
    this won't apply to you.
    May 2007
    Smile Zutale! A solution!
    *jumps up and down for joy* I... I have done it!
    And now I will explain how. First of all many thanks to everyone for the help!
    First I will mention that I am using MicroPro and the 149c DIY programmer.
    After explorer fuses a bit, I found that through micropro I could tell what the fuses were set to, and so. I was able to change the fuse to INTRC_IO on the programmer. And I did not have to make any device calls in pbp at all.
    With this osilator set to INTRC_IO it just worked.
    It may be worth mentioning that the pbp default seems to be HS.
    Anyways thankyou all again!
  1. RA6 & RA7 I/O setting on the 16F88
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2008, 19:32
  2. External osc defines
    By Mugelpower in forum mel PIC BASIC Pro
    Last Post: - 17th February 2008, 14:56
  3. 16F913 RA7 Pin control problem
    By Wayne in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 01:53
  4. 16f88 help
    By ccsparky in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2004, 17:50
