I am wondering if you can do the following. Bruce already suggested this. I am just reminding you of the possibility (to catch a problem) of debugging this technique offers.
if you see 3 flashes of the led, you have reached the splash screen code.Code:GOTO Start INI: assembly block (with return) to setup the chip Setup: routine (with return) to set initial state of variables, etc Start: Led = 1:pause 1000:Led = 0 GOSUB INI Led = 1:pause 1000:Led = 0 GOSUB Setup Led = 1:pause 1000:Led = 0 Splash screen is displayed here. Some initail instrument checks ( proper hookup, etc) are performed here Switch polling routine here rest of code body
Perhaps this will help you find if you are missing a return / stacking too deep. You may have a problem due to the limited caller stack size. Have you looked into this too?
Jerson
