Serout2 and Serin2 problem
Results 1 to 4 of 4
    Have not studied your code yet but two things I have noticed so far.
    1- Serial communications are VERY time sensitive, I did not see at the beginning.
    DEFINE OSC 8 'or what ever you are using
    This tells the speed that the PIC is running at.
    2 - A PortA pin is used for the serial. If the PIC has an ADC you will need to make that pin a digital I/O
    Another thing to do. Instead of making the whole code at once (the problem could be any where) start off by making a test code that will say blink an LED to see that the PIC is running while sending something out by serial. Same on receive. In other words, get one thing working at a time. Then start adding to the code.
    MrSafe's Avatar
    MrSafe Guest
    I have tested another method where the data is sent as the user inputs his value and it works fine HOWEVER with the array I hoped to store the inputs the user inputs and then send them out by one by using the string command for the method that sends each input as it is inputed I used serout not serout2 because from what I understand serout will not work with str commands
    MrSafe,
    I take it that you have the PICs talking to each other now.
    If you have not seen this current thread, http://www.picbasic.co.uk/forum/showthread.php?t=6778
    it might interest you.
  1. SLOW Serin2 and Serout2
    By dragons_fire in forum General
    Last Post: - 26th June 2009, 03:38
  2. Problem with serin2 serout2
    By jasem700 in forum mel PIC BASIC Pro
    Last Post: - 6th March 2009, 19:55
  3. SEROUT2 and SERIN2 commands
    By bangunprayogi in forum mel PIC BASIC Pro
    Last Post: - 4th August 2005, 10:03
  4. Simple PC Menu System with Serin2
    Last Post: - 3rd April 2005, 09:27
  5. Serin2 and Serout2 with or without level converter
    By fbestepe in forum mel PIC BASIC Pro
    Last Post: - 31st May 2004, 08:10
