Hello all,
Just to keep things simple and not going into alot of details here is my question:
Can you use a variable in the port settings?
Example....
for I = 0 to 7
if portb.I = 1 then xxxxx
next I
If so how do you setup the variable? (I var byte)
I have tired and tried and it always says:
"ERROR Line X: Bad variable modifier: .I."
What I am trying to do is scan a port for changes with out using 8 seperate If...then lines.
Any help is always appreciated.
Bill12780
SETUP:
16f873
easypic4 dev board
picbasic pro v2.47
using PM as compiler
