Assembly Language Conflict
Results 1 to 3 of 3
    Dec 2005
    Hendersonville NC
    Unhappy Assembly Language Conflict
    I am using Microcode Studio Plus with PIC Basic 2.47 (I used to have 2.45 but recently upgraded). I used to be able to use an assembly language statement to set the PIC configuration in a 16F870 on a line by itself as follows:
    @ __config _RC_OSC & _WDT_OFF & _PWRTE_ON & _LVP_OFF & _CP_OFF
    now I cannot use this anymore because I get an error as follows:
    Error[118] C:\rfprogs\picinfo\picbas~1\bingo.asm 122 : Overwriting previous address contents (2007)
    I have two problems with this error notice, first I recognize (2007) as being the address location where the PIC Config information is written, HOWEVER, neither the PIC Basic Software nor the Microcode Studio Plus software mention ANYTHING about what "Error[118] means, nor does anything mention what the "122" stands for. In fact I cannot find a list of error codes anywhere or what they mean. The manual mentions something about having problems when sharing variables between PBP and assembly, BUT as far as I know, I'm NOT doing that!
    Would someone please explain to me what is going on and what I need to do to correct this problem?
    Many thanks
    Kindest regards,
    Chuck Irwin
    Have a look here. I think that will answer your question.
    /Henrik Olsson.
    Dec 2005
    Hendersonville NC
    Default Assembly Language Conflice
    Thanks Hinrik! That helped a lot! I did this before but forgot about having to edit the *.inc file! Getting old and forgetful is NOT fun!
  1. Assembly Language inside PBP
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 12th October 2009, 21:52
  2. Multi Language Support on LCD ?
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 8th June 2007, 14:07
  3. Assembly Guru : Question
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 20th May 2007, 03:51
  4. Assembly Language + PBP
    Last Post: - 10th January 2006, 13:54
  5. Replies: 2
    Last Post: - 8th August 2004, 16:00
