Writing to SD card
Results 1 to 11 of 11
    Dec 2005
    Default Writing to SD card
    I have a need to write small amounts of data to an SD card. The data comes in discontinuous flurries of 4 byte chunks and I have about 7mS between chunks to write the 4 bytes to SD (and hopefully to RS232). A normal incident will have a total of 200-532 bytes but there may be incidents that have thousands of bytes.
    The examples I've found so far write 512 bytes at a time, using FRAM or RAM to accumulate a page prior to writing. I'd prefer to write each 4 byte chunk as it occurs.
    Is it possible to write smaller amounts than 512 bytes? Does anyone have a URL to an explanation of reading/writing to SD? Better yet, does anyone have an example of writing small amounts of data to SD?
    Dec 2005
    Quote Originally Posted by bbarney View Post
    I had already seen that and I interpreted it as requiring 512 byte writes. Am I misinterpreting it?
    Probably not I didn't really read it just thought you might not have seen the site before.this might help even though it's for proton
    Yes you can!
    Anyway the block must be closed with exactly 512 bytes.
    Absolutely necessary the "ProdManualSDCardv1.9.pdf" from Sandisk
    Gianni
    Dec 2005
    Quote Originally Posted by GioppY View Post
    Thank you! That looks like a great resource.
    Dave here's a link to a newer manual
    http://www.digitalspirit.org/file/?a...dv2.2final.pdf
    Mar 2006
    Default Proton to PBP
    Sir that code is cool!!! have you ever tried porting it to PBP? i would like to share it from you ifsoever
    Trully,
    Ryan
    Jul 2006
    USA
    That link doesn't seem to be working. I did a google search and all links for that file are from
    that website. They must have moved the file.
    Feb 2003
    Sydney, Australia
    That link is OK. Thanks!
  1. SD or MMC card as storage for logging
    By HYETİK in forum mel PIC BASIC Pro
    Last Post: - 16th January 2012, 02:07
  2. Replies: 12
    Last Post: - 4th March 2010, 21:20
  3. SD Card file attributes with SDFS3 ?
    By Chris Barron in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 09:18
  4. SD Card Filesystem like AVRDOS for Atmel
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 28th December 2007, 14:00
  5. Writing to an SD Card/PIC18F2480
    By divisionbyzorro in forum mel PIC BASIC Pro
    Last Post: - 19th March 2007, 15:02
