Error programming 16F688
Results 1 to 10 of 10
    Isle of Man
    Cool Error programming 16F688
    I am using PBP V2.45 with Microcode Studio V2.45A. When I try to compile a program for the 16F688, Microcode Studio gives the error message:
    Error in parameter "16F688"
    This happens even when the program is only 1 line or even no lines (just a comment)! Any ideas?
    Mar 2006
    Pennsylvania, USA.
    Just a guess, but you might try the patch for version 2.45 from MeLabs;
    http://www.melabs.com/downloads/P245A1.EXE, and see if that changes anything.
    Jerry.
    If your oscilloscope costs more than your car...
    Isle of Man
    Thanks for the idea. I downloaded the patch program and ran it. However, the program replies:
    "Nothing to do! The files are already updated."
    So no solution I'm afraid!
    Quote Originally Posted by manxman View Post
    That is not the correct response. From melabs Software patch for PICBASIC PRO™ version 2.45.: http://www.melabs.com/support/patches.htm
    If you try to patch an installation that has been patched previously, you will receive the error: "This program cannot update the installed version of PICBASIC PRO Compiler because of the following reasons: c:\pbp\PIC12F683.BAS: unknown version." If you see this, you don't need the patch.
    Just an observation
    Isle of Man
    Cool Error in programming 16F688
    Downloading this patch from Melabs and running it produces the same "Nothing to do" error message. I have had no problem compiling for other 16F*** and 18F*** PIC devices.
    Have you tried updating to the latest version of MicroCode Studio?
    The 2.45 patch only works if you have a version of 2.45 that was
    shipped before the update. You may have a version 2.45 that already
    included the update, so the patch doesn't do anything.
    I would try compiling from the command line too. That would at least
    tell you if it's MCS or PBP.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. DS1820 with 16f688
    Last Post: - 23rd May 2009, 06:07
  2. 16f688 <-> Max232
    By PlantBob in forum Serial
    Last Post: - 25th March 2008, 15:57
  3. Help with 16f688
    Last Post: - 21st October 2006, 00:12
  4. Direct replacement for 16F688
    Last Post: - 7th September 2006, 02:20
  5. Problem with 16F688 and Hserout
    By DWV in forum mel PIC BASIC Pro
    Last Post: - 19th March 2005, 06:37
