From c to pbp
Results 1 to 13 of 13
Thread: From c to pbp
    Jun 2006
    I have made the pcb and these days i will try if work.
    Jun 2006
    Quote Originally Posted by savnik View Post
    Thank you Bruce
    I test and work , but it should not all the delays they is same; PAUSE9
    Edit: I use the code as you post , without any change.
    Bombay, India
    The delays shown by Bruce are mistakenly wrong. The original code shows delay_cycles(59) That is delay for 59 cycles. So, by using Bruce's code as a start, you can make the delay for 59 cycles. This will give you the correct timings. Another thing, the oscillator is 20MHz. So, the initial define has to be
    define OSC  20000000
    cntr    byte    1
    delay_cycles59:             ' 2 cycles to get here
    asm
             MOVLW  11          ' 1 cycle
             MOVWF  _cntr      ' 1 cycle
    loop:  DECFSZ _cntr,F     ' 1 cycles  (3*17+1 = 52)
             GOTO   loop          ' 2 cycles
             nop                    ' 1 cycle
             return                 ' 2 cycles
    endasm
    The above has a subroutine to give you an exact delay of 59 cycles. You can call the function from PBP like this
             gosub  delay_cycles59
    Per Savniks' original post,
    How to change this code to picbasic pro.Also i want to use xtal 4MHZ
    I think he's looking for a similar function, but with a 4MHz osc VS 20MHz.
    If not, then of course the timing in my example would indeed be wrong.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2006
    Yes , I was looking for a similar function, but with a 4MHz Xtal.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. PBP, ASM and LST files
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th January 2010, 14:43
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
  5. PBP / XP Crash
    By pondindustrial in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 04:16
